Sponsored by:
Sponsored by: CARiD
EVO-X SST-330 S-AYC oil?
Old Jun 1, 2017 | 02:30 AM
Batsy's Avatar
Hi all, i'm looking to do a complete fluid change on my EVO-X SST-330 and am unsure as to the correct types, and quantities, of fluids to use, e.g. grade of S-AYC oil etc.
Any help, much appreciated, Al.
Old Jun 1, 2017 | 11:31 AM
Nkryptd1's Avatar
Do you have the owner's manual for the car? If so I believe it tells you what fluids and quantities for motor and drivetrain...
You can search the forums as there should be plenty of how tos for fluid changes or call a shop such as STM and ask.
Old Jun 1, 2017 | 10:26 PM
supwiddiss's Avatar
All of your fluids and capacities should be in your owners manual. I have a '12 GSR.
Even if a dealer swaps the fluids out I'm pretty sure they don't drain and refill the ACD pump juice. Supposedly it's not needed. and bleeding it is a pain.
There are methods to bleed it. Ign. on>gas to the floor>open bleeder...do it again and again.
Bleed while someone turns a wheel. I bled mine with the gas pedal method. And it takes 2 people. Not much bleeds out in each key on>pedal to the floor cycle.
Hint. Don't forget bleeding the brakes. Old fluid from the master cylinder/anti lock pump/brembos needs to be purged.
gally
Evo X Dyno Results
Sep 23, 2015 04:11 PM
Web9
Dec 14, 2012 04:49 PM
ak47po
Aug 13, 2009 05:39 AM
