Sponsored by:
Sponsored by: CARiD
ABS AYC and break problems?
Old Jun 1, 2017 | 11:53 PM
LOOKJUSTLOOK's Avatar
Is there anyone know what s going on with my car?
Here is the problem.When the car cold start,it shows everything is normal.But when I drive it for a while,like between 10-15mins,sometimes even shorter than 5 mins,the AWC signal would light up,and then the ABS signal.If I press the break pedal just right after the signal showed,it was very hard to press it.But after 1 pr 2 mins it back to normal.but the signal still there.
And sometimes I was driving on the low gears,like 1st or 2nd gear,the tire slipping signal would show up,and also the car was not moving properly.If I switch to the 3rd gear or higher,it would be run stable.
Plz help me
Old Jun 2, 2017 | 05:59 AM
Napalm_Enema's Avatar
Your AYC pump is going out, but lucky for you it is under a 100,000 mile warranty. Take it to a dealership and have them replace it. Then, since you drive in the snow I'm assuming, invest in an AYC pump relocation kit and put it in your trunk. That way it won't break again on you when you're past 100k miles.
RSMike
Apr 28, 2018 03:41 PM
Lion_Sam
May 5, 2015 05:49 AM
Livefast.eu
13
Apr 8, 2012 01:58 PM
tkklemann
Mar 8, 2007 08:03 AM
