Sponsored by:
Sponsored by: CARiD
Gas octane discussion.
Old Oct 10, 2011 | 12:24 PM
§treet_§peed's Avatar
Question Gas octane discussion.
Have any of you either tried and/or debated on putting a lower octane gas in your Evo? If you have please tell...
Old Oct 10, 2011 | 12:29 PM
gsrboi80's Avatar
Degrade to performance of a performance car. Hmmmmmm Nope thought never even crossed my mind to be honest
Old Oct 10, 2011 | 12:31 PM
Kracka's Avatar
Great question...if you want to damage your engine.
Running a lower than required octane will do nothing but hurt performance and potentially damage the engine. The stock ECU on a stock car can compensate for some octane issues, but if you're ripping around on 87-octane you will be knocking badly and causing your engine harm.
If your budget is tight skip the fancy coffee or bottle of soda, that alone will offset the cost of premium vs. regular.
If you just can't afford premium gas then the Evo is not the car for you.
Old Oct 10, 2011 | 12:33 PM
trick3d's Avatar
^^only response needed.
Old Oct 10, 2011 | 12:39 PM
I was just curious as to some opinions on here. I have seen this discussion on other forums and was wondering what some of you thought.
Old Oct 10, 2011 | 12:41 PM
grillpt's Avatar
I run 86 in mine all day everyday. Just to make sure the knock sensor is doing its job.
Old Oct 10, 2011 | 05:43 PM
Ladogaboy's Avatar
I wouldn't run <91 without a tune for that set up. Even still, if you want a custom economy tune, you'd want to weigh the cost of the tune versus what you'd save in gas price and mpg. However, most EVO owners are geared towards maximizing power and performance, not necessarily the inherent efficiency, so you'll have a little less support in that area.
Old Oct 10, 2011 | 07:09 PM
anEVOx's Avatar
So you're really only saving like $3/tank going to the lowest grade. If you're in that tight of a money situation then buy an economy car.
Old Oct 10, 2011 | 07:17 PM
Alpha X's Avatar
My owners manual says not to use anything less than 91 octane. I wouldn't dare put anything less than 93.
Old Oct 10, 2011 | 07:25 PM
Dynhamik's Avatar
If you consider running low octane, maybe the Evo isn't for you. I only run 100 now,but I ran 91 for a year. It's $6.79/gallon but I drive it only once or twice a week if that. Smells lovely.lol
Old Oct 10, 2011 | 09:25 PM
KJ82's Avatar
+ 1,000x another 1,000
Old Oct 11, 2011 | 11:06 AM
daleks's Avatar
On a road trip recently I got down to E and had to put in a couple gallons of 90 octane since the middle-of-nowhere station had just that. I checked the manual and it says you should use 93, but if unavailable use 91. It also said lower grade quality gasoline may be used, but only in emergency situations. My next tank was 93.
I've only ever been to one state where most stations carry 93: Missouri. All across Idaho, Montana, Wyoming, South Dakota, Iowa and Nebraska I only ever saw 91 as the best. Washington carries 92 octane in most places. The manual stating a need for 93 seems to be wishful thinking.
Old Oct 11, 2011 | 02:35 PM
trick3d's Avatar
OP im glad we had this discussion, as you can see there is none. Just fill up with as close of an octane to 93 as possible.
Old Oct 12, 2011 | 09:09 AM
AWDTerror's Avatar
I make it a point to scope out 93+ stations whenever I travel with my Evo. Usually you can count on the big name places like BP and Mobil to have 93+ in the midwest states. Missouri you can also count on having ethanol free 93+ octane.
Also for those in Missouri - 94 can be found in Springfield and Lebanon.
Old Oct 12, 2011 | 10:13 AM
TheBlade's Avatar
Kracka FTMFWin!
