ARK STB w/ FAST key
ARK STB w/ FAST key
So.. I'm looking into this part...
http://www.arkdesign-us.com/products...le-turbo-timer
And the more I look at it, the simplicity of install and placement is appealing. I've doing some extensive bolt on work to the car, and I think a good turbo timer wouldn't not be a bad decision with pushing the turbo harder than factory now.
that being said, tell me why this is a bad idea. I know the FAST key won't arm while the timer is running. However, I know FAST has a 30 second timer on it bfore it auto locks the doors if the ignition is cut and the doors closed. now I imagine it takes 5 - 10 seconds to get out and close the car door after cutting the ignition. by this logic the car should auto lock itself 35-40 seconds after I cut the ingition. leaving a very short period of time the car will be running and unlocked simultaneously.
With turbo timers, has anyone found they can still manually lock the doors with the button on the handle, or with the FOB? Just n general.
Thanks again all.
Thanks again all.
I was checking this piece out myself and I got rejected when I tried to make the purchase online. Let me know if it works out, I might still get one...
I've heard this too. The reason for a turbo timer from my understanding is to keep the oil circulating through the turbo to prevent coking, but when you have a water/oil cooled turbo its pointless.
Turbo Timers are a thing of the past, similar to any of these piggy back tuning computers. Idle for a few seconds before shutting down and don't kill the engine after doing 10 quarter mile pulls and your all good.
If you really want some kind of turbo protection look into a simple manifold gasket (thick thermal isolator gasket) or put the money into the cooling system, a high performance radiator or pump, etc.
I'm not aware of any turbocharger that isn't oil cooled. Non-water cooled, yes. Non-oil cooled, no.
If you run synthetic oil, do not turn your car off immediately after beating the crap out of it or steady state cruising in the higher RPM range where the ECU is in closed loop and turn your car off immediately, that thing is a waste of money.
Premature turbocharger failures caused from coking is fairly uncommon with synthetic oils.
Ancyker
22
Apr 4, 2016 04:58 PM
Jake26
Evo X How Tos / Installations
Nov 8, 2010 03:49 PM
2011, ark, evo, evolution, evolutionm, fast, fastkey, gsr, install, installing, key, stb, timer, turbo, willfastkeyworkforevo8
