Sponsored by:
Sponsored by: CARiD
Is this normal?
Old Nov 18, 2011 | 12:26 PM
  #46
Sev's Avatar
Sev
Yeah, that was out of the question anyway...just out of the sky.
Old Nov 18, 2011 | 06:02 PM
  #47
Fly'nHaYN's Avatar
Dude have your brother drive your car to see if you or the car needs boost
Old Nov 18, 2011 | 06:19 PM
  #48
Thegame's Avatar
The only way a boost leak would cause that bad of a power drop is if an entire hose popped off. That should be easy to locate.
Old Nov 18, 2011 | 06:46 PM
  #49
Sev's Avatar
Sev
lolloloololol
Edit: I just went WOT again just to be sure, lo and behold it hit boost but only @ WOT, nothing less.
Old Nov 18, 2011 | 07:43 PM
  #50
WarmMilk's Avatar
everyone stop freaking him out that there is something wrong with his car, he was part throttle, it is IMPOSSIBLE to tell if there's something wrong with his car from that vid. there is no way around that. nobody on here know's what he did with his foot therefore we cannot know if the car is behaving normally or not.
Sev
first of all, you were making boost. trust me, it'd be slower than that at WOT with no boost. in our cars boost comes on fast enough that you don't feel spool. in wrx and sti's on the other hand, it has a little more lag so you feel the spool up, thats prolly why you're thinking you've never felt boost in your car. drive your car in third gear and floor it from 1500ish rpm, then you'll feel some spool up
secondly if you really want an opinion post a full throttle vid... to the rev limiter.
Old Nov 18, 2011 | 08:16 PM
  #51
Sev's Avatar
Sev
Sev
Yeah, I did do WOT but didn' take a vid. I did WOT a few days ago and I didn't really feel anything but when I did it again tonight I felt it boost and the car pulled really hard. So looks like nothing is wrong after all, maybe this car doesn't boost in first gear unlesss ur WOT?
Old Nov 18, 2011 | 08:25 PM
  #52
Panda_stunter's Avatar
It will boost but ever so slightly...even at partial throttle.
Do u hear the bov go off when shifting or letting go of the accelerator?
Old Nov 18, 2011 | 08:26 PM
  #53
WarmMilk's Avatar
^you can't hear the bov with the stock intake
it should make boost part throttle or full throttle. from that first vid, i'm 95% sure your car is perfectly fine. But if you feel something is wrong with it, by all means take it to the dealer and have them check it out, your car being brand new and stock engine wise they shouldn't give you any problems. I'm betting there's nothing wrong with it.
Old Nov 18, 2011 | 08:30 PM
  #54
^ yes u can, it's faint but u can hear it. Turn off the radio, crack the window just a tiny bit on the driver side and u can hear it.
I know coz that's one of my joys when first got my X
Old Nov 18, 2011 | 08:34 PM
  #55
WarmMilk's Avatar
well, you're right, but its to faint to hang the diagnosis of his car on that
Old Nov 18, 2011 | 08:36 PM
  #56
HAHAV8's Avatar
Why don't you make another video of you doing a 1 to 2 WOT pull. Or even do it in 2nd or 3rd if its easier. That way we will be able to tell you if your car has an issue.
If you aren't boosting in 1st, you won't be boosting in any other gear either. Which means you probably have a serious boostleak, from my understandings is fairly common on the rubber IC hose from the factory.
Old Nov 18, 2011 | 08:49 PM
  #57
WarmMilk's Avatar
this, and while you're at it do a full 3rd gear pull also (idle to limiter)
never heard of this and never had this... I upgraded my upper pipe 2 weeks ago, my lower is still stock... tracked my car with stock IC piping with no issue
Old Nov 18, 2011 | 09:06 PM
  #58
HAHAV8's Avatar
^I've just read that on here a few times, I don't have any experience with boost leaks on the stock hose, as I have an ETS UICP, that I upgraded within the first month of ownership.
Old Nov 18, 2011 | 09:20 PM
  #59
evokerfes's Avatar
I also never had any boostleak on the stock rubber UICP.
Old Nov 18, 2011 | 09:53 PM
  #60
Evostare's Avatar
This thread gave me a headache. User error I'm sure. Like others have said - post a video of you going WOT, we cannot help you otherwise.
