3.5in or 4.0in Intercooler?
Seriously, the 3.8 Garrett core available in the CBRD IC, and BR "Race" IC's is the way to go on VIII's and IX's. This is hands down the most efficient core available in an off the shelf IC for the VIII's and IX's.
You can get the Garrett 3.8" core in an IC from ETS as well on special order. Talk to Michael at ETS. You may want to talk to Chad to find out how his Garrett cored IC works in unison with the CBRD BBK as well.
there is a general misunderstanding with intercoolers/sizing/efficiency-
on a small turbo at high boost (say over 25 psi) you will create ALOT of heat--- and NEED a big heat sink to remove it---
we've tested all kinds of intercoolers, bar plate, tube fin, vertical, horizontal... etc...
and the big mass thick cores work well (unless you have an ambient air issue for cooling- as we found on some evo X's)...
just an FYI-
cb
just an FYI-
cb
This man is correct.
This is the exact reason we recommend the larger intercoolers for the guys pushing the stock turbochargers or stock frame turbochargers to the limits. The 4.0" allows for more air flow and greater cooling with lower intake air temps. It's a win/win. This is also why you see some of the guys with 35r turbochargers running 3.5" intercooler w/o any problems and lower intake air temps. It has to do with the turbo being in it's efficiency range which will result in lower IAT.
Thansk!
Michael
Thansk!
Michael
just an FYI-
cb
just an FYI-
cb
MichaelUWright
117
Oct 14, 2016 06:01 PM
ETS Michael
Evo X Dyno Results
148
Feb 13, 2014 04:58 PM
ETS Michael
ExtremeTurboSystems.com – WA
17
Jan 24, 2013 09:09 PM
pd9000
13
Aug 14, 2012 04:36 PM
35, 35in, 3in, big, ets, evo, evolutionm, fmic, inout, intercooler, piping, recommendation, size, stock, turbo
