Sponsored by:
Sponsored by: CARiD
grindin noise when backing up??
Old Jan 16, 2012 | 09:54 AM
Evolution Z's Avatar
whenever i am backing out of my garage or parking space or doing a 3-point turn etc (basically when the steering rack is at full tilt) ... there is a heavy grinding sound coming from the the front wheels.
i have stock wheels, stock suspension, and stock brakes.
basically there are two things that i think it *may* be, and if it is one of the two, is it normal or something i should have checked out.
1.) tire rubbing on the wheel well? could be.. but the noise sounds more like metal on metal...
2.) is somehow the brake lines crimping up therefore engaging the calipers on the rotor? or is it the pad just not used to going backwards on the rotor and is scraping any stuff off?
any help is cool; thanks
Old Jan 16, 2012 | 12:40 PM
artax's Avatar
Wheel well may sound logical. The wheels when fully turned could be rubbing on the airvents in the fender liner.
But if that is case then it should be doing that when going forward as well in my opinion........may not b the wheel well.
Old Jan 16, 2012 | 04:25 PM
santeller's Avatar
Sounds exactly what i had wrong and it was at 500 miles. broken axle.. have the dealership look at it.
Old Jan 16, 2012 | 07:31 PM
uhh what. how was your axle broke?
Old Jan 16, 2012 | 11:39 PM
AFD's Avatar
AFD
Usually this.
Mine does it quite often when backing out of the driveway and onto the road.. after that, the grinding pretty much goes away for the rest of the day.
https://www.evolutionm.net/forums/ev...ip-rotors.html
https://www.evolutionm.net/forums/ev...-grinding.html
Old Jan 17, 2012 | 03:42 AM
Alpha X's Avatar
My car does the same thing. I thought it was just me.
Old Jan 17, 2012 | 01:02 PM
Originally Posted by AFD
Usually this.
yeah thats what my largest hunch was.
also- good info, thank you sir
Ayyrock
Jul 20, 2015 04:47 PM
McSlides
Oct 30, 2013 08:31 PM
2plaz
Apr 7, 2012 11:13 PM
Helix
Mar 2, 2012 04:28 PM
ezzey
32
Aug 15, 2011 11:47 PM
