Sponsored by:
Sponsored by: CARiD
2011 evo x not idling steady
Old Jan 16, 2012 | 01:01 PM
vietdragontekx's Avatar
Is this normal? My 2011 evo x with 2000 miles, rpm sometime bounce a bit at idle. it is not steady and bounce 100 rpm up and down a little randomly. But when it warm up, it seem tp be more steady
here a video if it, you can see the needle moving.
http://tinypic.com/r/s1t5ef/5
Old Jan 16, 2012 | 01:13 PM
rcheung's Avatar
Thats the first thing i noticed when i bought my X as well. Other members report the same issue so I don't worry about.
Old Jan 16, 2012 | 01:16 PM
Kracka's Avatar
It's fine. Do you have your A/C or defroster on?
Old Jan 16, 2012 | 01:19 PM
yeh i had it on at first and off in the last half of the video
oh okay thanks
Old Jan 16, 2012 | 01:22 PM
Kracka's Avatar
Anytime something cycles that puts a load on the engine your RPM's will fluctuate while the ECU compensates (A/C, alternator, power steering, etc.).
Old Jan 16, 2012 | 01:27 PM
Widoww's Avatar
Lil 4 banger ppl,any type of load make the rpm fluctuate. 100rpm is nothing..if it were 500+ then we'd need you to check that pesky vac line
Old Jan 16, 2012 | 01:30 PM
it even fluctuate when i am doing nothing. it just slight move up and down a bit, i guess it is normal then
Old Jan 17, 2012 | 06:52 AM
rcheung's Avatar
It looks like a evo 10 quirk. I could be sitting at idle, not using the brake, fan motor completely off and my idle still goes up and down. I have checked the vac line under the engine cover and it doesn't seem like it would cause an issue because that sucker is glued down (at least on the 2011 models).
Old Jan 17, 2012 | 06:53 AM
rcheung's Avatar
The 4 banger is not the problem. I had an evo 8 for 7 years and didn't have this issue.
Old Jan 17, 2012 | 07:51 AM
mirkendargen's Avatar
Yeah mine does the same, floats ~100RPM up/down when sitting with no accessories on. I wonder if the idle air controller (or just the throttle since it's drive-by-wire?) over compensates both ways, making it just constantly bump up and down and never sit at its target.
Old Jan 17, 2012 | 11:57 AM
i heard the evo X tune from factory is ****ty. it runs really rich. my friend had the same problem and he took it to church automotive tuning. the car gain 40 extra whp, 3 more mpg and the idle is dead on now without any fluctuation from just a basic tune.
Old Jan 18, 2012 | 04:05 PM
3BEEPS's Avatar
mine also did that until I got it tuned
Old Jan 18, 2012 | 04:51 PM
jdm_ed's Avatar
Mine was crazy (with a tune that the previous owner had) and after i installed a cobb ap it all went away. Later i Uninstalled the ap, removed the fuel pump relay for a few minutes, replaced and switched on and the car is idling beatifully... Beats the hell out of me but i know that did something. (In my case it was a horrible 500 rpm swing that would go up and down regardless ac was on or not.)
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
TURBO_S2K
26
Dec 10, 2016 09:53 PM
Stubbie68
Jun 29, 2015 03:45 PM
lapoune
Aug 22, 2012 03:47 PM
expl0d
Jul 18, 2004 09:01 AM
