Having a leaning out issue(video included)
Every time i accelerate, it happens to just lean out. This issue came to light one night that i over boosted and the dipstick popped off and i threw 4 codes
P0134
P0172
P0456
P0300
Current mods are:
ETS 3.5" intercooler kit
Primo 3.5" intake
T3 6262 DBB kit
AMS fuel rail
FIC 2150's
manley I beam rods
Weisco Piston std
Acl rod bearings
Supertech valvetrain kit
AMS Cams
AMS tp
Perrin exhaust
Exedy stage 2 Clutch
evo 9 CMC conversion
On E-85
Has anyone experienced this? Or can shed some light on this?
I cant even make it up a slight hill because the rpm just drops
http://www.youtube.com/watch?v=6OlE8...e_gdata_player
P0134
P0172
P0456
P0300
Current mods are:
Primo 3.5" intake
T3 6262 DBB kit
AMS fuel rail
FIC 2150's
manley I beam rods
Weisco Piston std
Acl rod bearings
AMS Cams
AMS tp
Perrin exhaust
On E-85
I would check fuel pump relay, and the fuel press reg vac hose first. also you are throwing code for system too rich and front O2 sensor, and evap so since you over boosted it sounds like some hoses might be pooped off.
I think it is your fuel pump relay put the high beam relay in the fuel pump one and see what happen. I had the same thing happen to me but it was ok after I shut it off and turn it back on but the sel will stay on.But mine would not let me boost pass 12psi. Good think for the aem wide band.And sense you can make it up the hill you might got a vac. Leak like m86 said
Did u try switching the relay just to see if is the fuel pump relay problem all the black are like the same relay.The high beam one would be the best because we use that less.gl
