Having a leaning out issue(video included)
if your car is modified you should get one step colder
"The "steps" in this book were actually shown as funny line-drawings that showed little bits of "heat" being "radiated" one "step" up into the cylinder head, then "two steps" deeper away from the combustion chamber, etc. disappating the heat out and away from the spark plug tip"
Prior to leaning out, the new plugs actually solved my other problem, if I had the car running and then shut it off, I wouldn't be able to turn it on unless I would start it with the gas pedal pressed, and now with the new plugs, it starts up like a champ
Update:
The first time I switch the relay, I just switched it with another black relay, now I switched it with the green one that's right next to the black one and the car is running 100 times better
turbocheese
16
Nov 19, 2015 09:16 AM
itzwolf
Feb 10, 2015 04:34 PM
murlo26
Jul 2, 2012 07:19 PM
