Sponsored by:
Sponsored by: CARiD
signs/symptoms of chain stretch?
Old Feb 21, 2012 | 09:51 AM
Evolution Z's Avatar
Red face signs/symptoms of chain stretch?
Hello again,
just wondering what are some of the audible symptoms of chain stretch? my motor has a kind of, only-sometimes, wierd-sounding idle. obviously its pointless trying to describe without a video, but im at work right now lol.
from what i've read here, the chain issue just happens without caution... but i'm wondering if anyone remembers any pre-emptive symptoms to the chain failure.
the sound is a light tapping, sometimes louder than other times, the noise may fade in-and-out of volume from here to there
thanks
Old Feb 21, 2012 | 10:25 AM
scarryy's Avatar
It should throw a code, not sure of the number, but it reads as timing chain related.
Old Feb 21, 2012 | 10:30 AM
AWDani's Avatar
Lifter tick? Does it do it mostly when it's cold? Go away after the car warms up?
Old Feb 21, 2012 | 10:36 AM
Get Rad's Avatar
You will throw the P0017 Exhaust cam sensor code. I am having the same issue right now and am bringing it into Mitsu on friday.
Old Feb 21, 2012 | 01:14 PM
RevLimiter's Avatar
That sucks bud, Are you keeping your test pipe on there ?
Old Feb 21, 2012 | 01:51 PM
Get Rad's Avatar
I reinstalled the stock cat this weekend which was a PITA. The nut on the end that connects the mid pipe stripped when I was uninstalling it so when I when to reinstall it the bolts wouldn't thread so I just hacked it off with a saws all and presto problem solved lol.
I just didn't want the dealership giving me crap for not having a cat installed lol
Old Feb 21, 2012 | 01:53 PM
RevLimiter's Avatar
yeah, You have to go through all that bs when you making a trip to the Stealership.
Good luck, hopefully its nothing serious
Old Feb 21, 2012 | 01:56 PM
evo8dreamcar's Avatar
The p0012 code will come up. I am actually doing a chain Thursday for one (working at a mitsu dealer)
Old Feb 21, 2012 | 02:07 PM
hmm, well so far, so good. not a single code thrown. (knock on wood)
Old Feb 21, 2012 | 04:15 PM
It takes about 1 hr to check it. Top dead center the motor and take valve cover off. Look down the chain and see if it is passed the indicator or not. Firewall(exhaust) cam look down and you can see if it passes the indicator mark or now. If under Warranty just bring to a dealer
Old Feb 21, 2012 | 08:04 PM
looks like I'll be doing this when my aluminum valve cover comes in
Old Feb 21, 2012 | 08:15 PM
olo's Avatar
olo
Ya I got cel on mine . It "should" but there have been cases that didn't and the chain was extremely stretched.
Old Feb 21, 2012 | 08:44 PM
IBoughtASupra's Avatar
Evo 10's are timing chains now?
Old Feb 21, 2012 | 10:47 PM
ptakats's Avatar
My car threw a p0012 code tonight and I have been having poor idle issues too. When I'm sitting at a light the idle will be stable then flutter above and below 1k then stabilizes again. I just read about a service bulletin in reference to the 08-11 x's and it had to do with this same cam sensor code. Does anyone know more about this? Is it legit?
Old Feb 22, 2012 | 05:36 AM
I work at a Mitsubishi dealer. The p0012 is the vvt to retard aka timing chain stretched.
