Sponsored by:
Sponsored by: CARiD
BOV restrictor pill
Old Mar 5, 2012 | 09:14 PM
Funsuby's Avatar
BOV restrictor pill
Hi guys,
Long story short, I flashed my 08 gsr with the Cobb AP stg 2. As per Cobb I needed to removed my BOV restrictor pill. On the Coob website, they are showing 2 exemple of restrictor pill which to me kinda look a motocross jet when adjusting a carb. Mind l looked like this:
http://img521.imageshack.us/img521/6889/img0802a.jpg
http://img546.imageshack.us/img546/3898/img0801m.jpg
http://img820.imageshack.us/img820/3076/img0799yp.jpg
Does this look right to you guys??
Thanks.
Old Mar 6, 2012 | 03:30 AM
Robevo RS's Avatar
i dont know what is a BOV restrictor pill.
Old Mar 6, 2012 | 04:03 AM
ChopShop's Avatar
that looks correct to me buddy
Old Mar 6, 2012 | 04:14 AM
AFD's Avatar
AFD
^^ Needs to be removed for Cobb AP stage 2, and probably for other tunes as well..
http://www.accessecu.com/accessport/...Pill_Instr.pdf
And the OP's pill looks slightly less restricted than other ones I've seen for the X, but it does look identical to this one from a 9..
Maybe they've stayed the same throughout generations? Or maybe pic above was wrong pill.. think there are 2, but only 1 needs to be removed.
Old Mar 6, 2012 | 07:32 AM
Funsuby's Avatar
Thanks guys
Old Mar 6, 2012 | 07:37 AM
user 629782012's Avatar
thats what my pill looks like too. since i'm at high altitude my boost pill is removed to get my boost from 20psi to24 ish psi. i sometimes hit 26 but not often..
if i go down elivation i'll hit 28 and the boost system will fuel cut me. so when traveling i'll put the pill back in.
Old Mar 6, 2012 | 10:34 PM
mx931's Avatar
yea thats it
Old Mar 6, 2012 | 10:45 PM
import111's Avatar
See what boost you are hitting before you remove the pill. You may not need to remove it. I hit 27 PSI with the pill still in on COBB stg 2 91ACN.
Old Mar 7, 2012 | 12:04 AM
ravenjam's Avatar
I see a boost controller in your future
Old Mar 7, 2012 | 03:43 AM
bmxking45's Avatar
I have my pill still Lin there and I spike 27 on cobb stage one = not good. I had to switch over to stage one LWG and it seems to be much better.
Old Mar 20, 2012 | 02:05 PM
iroc-evo's Avatar
bmx, what year is your evo?
Old Mar 20, 2012 | 02:10 PM
EvilRob's Avatar
I hit 25-26 with my pill still there check before you remove it. Cobb instructions state that if you are not hitting your target boost then you should try removing the pill, and not doing it right off the bat.
PS and people wonder when their engine blows up.
Old Mar 20, 2012 | 06:06 PM
bmxking45's Avatar
2010 MR Touring
Old Mar 21, 2012 | 05:09 PM
iroc-evo's Avatar
I was hitting 26+ psi on cobb 93 oct stage 1 with just cat-back and hit boost cut a couple of times.
After 91 octane stage 2 91 oct flash and adding hfc, i'm only hitting 21 psi WITH boost pill. I don't wanna remove the boost pill until i get boost/wideband gauges to monitor everything.
2011 GSR all stock except for mods stated above
Old Jul 11, 2012 | 09:17 PM
1badgsex's Avatar
there saying ppl with mr or ra to leave the boost pill in cause the way the car loads up the trans your more prone to overboost or boost spike
jakermeister
Lancer Aftermarket Forced Induction Tech
48
Sep 7, 2012 02:49 PM
ToxicFab
Aug 27, 2011 11:29 AM
Rexpeed
EvoX 'For Sale' Exterior Styling
57
Aug 7, 2011 08:24 AM
NickieBlaine
For Sale - Part Outs
11
Apr 29, 2011 08:16 AM
TurboXtreme
Feb 3, 2006 08:35 PM
