Sponsored by:
Sponsored by: CARiD
bore/darton block sleeves
Old Mar 8, 2012 | 05:21 AM
novaspyder87's Avatar
hi guys, I have a question!!! why do people put darton sleeves in the evox??
whats the problem with only porting(bore) to 90mm the stock block itself?
if i do understand how the darton sleeves work.....you have to take out the stock block cylinder and then you put those darton sleeves in.......and if you want a 2.2 you have to bore those darton sleeves that you just put in!!!
so my question was and is....... why its not good the bore the stock block???
if im all wrong could somebody explain to me please!!!
ps: im looking to go with a 2,4.....so YESSSSS i know about the manley stroker kit .....i just want to know if i really have to buy some darton sleeves and to pay like 1000 for all that after all to bore to 90mm youre not taking out a lot!!!
tks guys!!!
Old Mar 8, 2012 | 08:07 AM
01CBR929's Avatar
The problem with the x is the.oem block is aluminum and cannot handle crazy high cylinder pressure before "venting" then block. In order to handle the high levels of power you have to get sleeves that are much stronger than the stock block.
Old Mar 8, 2012 | 08:08 AM
RealStreet's Avatar
The more you bore it the weaker the sleeve. The factory sleeve can only handle so much. Darton makes a MID sleeve that you can bore up to 90mm.
Old Mar 8, 2012 | 09:28 AM
ok tks guy thats exactly what i tought tks a lot
SP33D FREAK
May 15, 2015 02:15 PM
SP33D FREAK
May 15, 2015 07:34 AM
Englando
11
Sep 25, 2012 05:39 AM
GSR ONE
Apr 23, 2012 12:15 AM
BigValley
20
Aug 16, 2009 11:47 AM
