Sponsored by:
Sponsored by: CARiD
Axle problems?
Old Mar 9, 2012 | 05:19 PM
planb x's Avatar
Axle problems?
Im having some problems with my axle seal. Its leaking and i have fluid all over the place. I had the seal replaced once already about 6 moths ago. Is anyone else having this problem? Could my axle be bad? I ordered a new seal and it will be here mondday. Also should there be any play with the axle? I can pull on it and it moves a little but not to much. I searched but with no luck. thanks
Old Mar 14, 2012 | 07:44 PM
planb x's Avatar
here are some pics of the seal.
I replaced the seal today hopefully that takes care of the leak.
Old Mar 15, 2012 | 10:32 AM
CFMP RAblue's Avatar
Have you checked all ur ball joints and susp for that wheel? It's a bit of long shot but if everything was a bit loose it could allow the axle to slide out a bit and leak. Or ur bearings in the axle are out of spec after so many miles. I see u have an 08 it's just a shot in the dark tho.
Cheers
Old Mar 16, 2012 | 09:20 AM
ikt's Avatar
ikt
i had this happen on both my Evos, the old part number was really thin and prone to tearing on install. According to my dealership, there is a new part that is a thicker seal.
BaLListic_EVO
24
Oct 13, 2016 02:59 PM
jdmauto
Aug 6, 2016 06:49 PM
JTCB
Apr 8, 2015 02:46 PM
jhoganusaf
Jan 28, 2014 09:25 PM
AcePitcher11
17
Feb 4, 2012 10:54 AM
