Sponsored by:
Sponsored by: CARiD
Upgrading the stock turbo
Old May 19, 2012 | 04:53 PM
SaiKyo's Avatar
So i want to replace my stock turbo with FP red, FP red turbo's don't come as a "kit".
I currently have : AMS down pipe, AMS test pipe, Tomei exuast, AMS filter, AMS intercooler with upper and lower piping. the question is, is there anything else i have to upgrade before installing the FP red?
Thank you.
Old May 19, 2012 | 05:07 PM
08GsrX's Avatar
Injectors, fuel pump, boost controller, probably a BPV depending on how much your going to be boosting, at the very least crush your BPV.
Hopefully by AMS filter you mean intake?
Old May 19, 2012 | 05:40 PM
BaumBizzle's Avatar
Damn…AMS'd out huh? NICE! Prob gonna be putting down some power so keep a clutch in mind shortly down the road. When you get tuned try to keep that WTQ around 360-370ish or else plan on buying internals shortly after. If it doesn't spool quite to your liking you could throw some cams in there….nice parts bro!
Old May 19, 2012 | 05:43 PM
spider21's Avatar
I wouldn't go to a red without cams. Look at MAPS EF2
Old May 19, 2012 | 07:54 PM
SaiKyo's Avatar
yes its the AMS intake
Old May 19, 2012 | 07:56 PM
SaiKyo's Avatar
AMS all the way , I'm thinking of upgrading the clutch for the next step, but i need a tune first
Old May 19, 2012 | 07:58 PM
SaiKyo's Avatar
My goal is 450-480 HP, EF2 can reach that?
Old May 19, 2012 | 11:25 PM
Snakes709's Avatar
dont need cams for fp red, it will help but not required at all
You can hit those numbers on a fp red, but you will need a built engine. I have the following...
Ball Bearing FP Red, ported, 25psi wga and hiflow oil feed line
FIC 1100cc Injectors
Walbro 255lph fuel pump
AEM Fuel Pressure Regulator Kit
AMS CAI
AMS UICP
AMS LICP w/ TiAL QR bov
ETS 4" IC
AMS Widemouth DP
T1R Resinated TP
Tomei Expreme exhaust
Grimspeed 3 port
Clipse tuned on 94 octane @29psi, tapering to 27psi, making 423hp 382trq. I'm on stock internals and plan on doing alot of track days so the tune is conservitive.
Also i fried the clutch so the following is on its way...
ACT HD 6 Puck clutch kit
Streetlite flywheel
AMS CMC kit
http://www.youtube.com/watch?v=C1nyrzOgprE
http://www.youtube.com/watch?v=RkFqxhLv_FE
Old May 20, 2012 | 12:23 AM
SaiKyo's Avatar
AMS CAI
AMS UICP
ETS 4" IC
AMS Widemouth DP
T1R Resinated TP
Grimspeed 3 port
Streetlite flywheel
AMS CMC kit
thats a nice setup {thumb up}, but I'm not planing on building the engine (for now)
how about the EF2 or EF3?
Old May 20, 2012 | 07:18 AM
spider21's Avatar
So what level do you want to hit without building the motor?
Old May 20, 2012 | 08:49 AM
Snakes709's Avatar
well you arent going to hit any higher then 450hp 380trq without a built engine. Well you can hit those numbers but it wont be for long. I'm at the "safe" limit of the engine without it being built and theres still tons of room for the FP Red to keep going. I could have my tune be leaner, more timing and more boost, but where ill be doing HPDE days, its safer to keep it where its at and im happy with this setup. The car pulls like a raped ape.
Old May 20, 2012 | 11:10 AM
SaiKyo's Avatar
my goal is 450
Old May 20, 2012 | 12:55 PM
spider21's Avatar
my goal is 450
Prepare for a built engine at that level
Old May 20, 2012 | 01:52 PM
NFSLancerRA's Avatar
What you will need:
Engine: Pistons, Rods, Bearings, Headstuds, Head Gasket
Fuel: ID1000cc Injectors (93) or 1650cc or greater (E85), DW65 Pump
Misc.: 3-Port, Turbo Inlet Pipe (?), SS Turbo Oil Lines (?), BPV
Transmission: ACT HDSS Clutch, Magnus CMC, maybe a Jack's Transmission consult?
Old May 20, 2012 | 02:14 PM
SaiKyo's Avatar
i guess i have to prepare for a build
thanks guys for the replies, really appreciate it
