Sponsored by:
Sponsored by: CARiD
New Evo X, Overcooling?
Old Jun 1, 2012 | 03:53 PM
Jaten's Avatar
Hi there, Well, bought a brand new 2012 Evolution X GSR back in march, and I had a question about how warm the engine should be when you drive. All the vehicles I've owned before the temperature reading would sit right in the center of the meter. On the Evo I notice it tends to go quite low, as in only about 1/4 the way up the gauge. when I'm cruising at freeway speeds. In city driving its fine, stays right smack in the center of the gauge. I've contacted the dealer and asked their opinion, they seems to think its ok, But I figured I'd register here and ask you for your opinions.
Old Jun 1, 2012 | 03:56 PM
Iowa999's Avatar
Is your AC on? My X runs at about 198*F (oil temp) with the AC off and 177*F with the AC on, due to the fan kicking into high when the AC is running.
Old Jun 1, 2012 | 04:05 PM
Jaten's Avatar
No, my AC is off ambient temperature when I was driving it today was about 72 F. The car is bone stock, being brand new and all. I wish I had actual temperature numbers for water and oil to post for you, but unless there is some way to display that in the mini LCD between the tach and speedo I won't have those.
Old Jun 1, 2012 | 04:25 PM
SpardaVR4's Avatar
Non of my cars ever reached the middle of the temperature gauge. They always sat 3/4 of the way to the middle.
Old Jun 1, 2012 | 04:35 PM
Snakes709's Avatar
its normal. As you are going higher speed on the highway, more air is hitting the rad/intercooler which will cool the system alot more. When you are in the city, not as much air is getting to the rad/intercooler and it will heat up.
Old Jun 1, 2012 | 04:41 PM
Jaten's Avatar
probably just a side effect of the temperature being directly in the center of dash instead of off in some corner, tend to pay more attention to it.
Old Jun 1, 2012 | 04:42 PM
SOEuro's Avatar
maybe your thermostat?
Old Jun 2, 2012 | 02:54 AM
Panda_stunter's Avatar
I was gonna say the same thing, stuck thermostat would do that.
Old Jun 3, 2012 | 06:51 AM
WaitForIt's Avatar
I have a '12 and since I've owned it it has never gotten above half way. Usually toggles between the halfway point and one notch below halfway.
Old Jun 4, 2012 | 01:55 PM
johnys9292's Avatar
Normal
Old Jun 4, 2012 | 02:07 PM
TheBlade's Avatar
Mine goes right to the halfway mark, and ODB2 scanner app shows water temp at 183 low, and 198 high usually.
The 198 is usually when I have the AC on when it's about 110F outside for ambient air temp.
Old Jun 4, 2012 | 04:38 PM
Halfway and 1 notch below halfway is perfectly normal.
Old Jun 4, 2012 | 04:44 PM
JRally's Avatar
Mine warms up to one notch below halfway and never moves... I've driven it in weather from 30 degrees to 80 degrees, the same all the time.
Old Jun 4, 2012 | 04:50 PM
humpevo311's Avatar
I wouldnt worry about it, a turbo car running cool is always a good thing. In the summer even if a thermostat stuck open it would likely build heat. If winter comes and you cant get heat, then take it in.
Old Jun 4, 2012 | 05:41 PM
Thermostat that's stuck open would cool a car for about 1.5-2 hours, then it would overheat. Reason being the coolant never gets a chance to cool down, it's always on circulation. Doesn't matter if it's cold or hot weather. The only difference would be, on cool weather, the coolant would stay cool a little longer before it overheats.
