Sponsored by:
Sponsored by: CARiD
Engine build quote
Old Jun 12, 2012 | 07:51 PM
BaumBizzle's Avatar
Engine build quote
Wondering if anybody can give me an idea of roughly how much I'd be looking at if I had a reputable shop install rods and pistons etc not including parts. I guess about how many hours you think I should be charged for?
Old Jun 12, 2012 | 08:22 PM
Anarchy99's Avatar
$1200 or so
Old Jun 12, 2012 | 08:59 PM
BaumBizzle's Avatar
So roughly $2k for rods, pistons, bearings, studs and install....well worth the peace of mind I suppose
Old Jun 13, 2012 | 05:42 AM
Robevo RS's Avatar
Rktmotors. Give them a call and explain them what you need. They can give you a quote from first hand
Old Jun 13, 2012 | 05:45 AM
Robevo RS's Avatar
For thar price of the build you will not get a piece of mind, rather nightmares...
Also you need gaskets oil etc, small items add on very fast to the final bill.
Old Jun 13, 2012 | 06:20 AM
lowkey's Avatar
Registered User
Go to a shop and get a quote. Make sure they factored in gaskets, o-rings, bearings, oil, coolant. Head, main studs and bearings are expensive too. You can compare their quote against an already built short-block from MAP. I'm just going through that. It's an eye opener.
Old Jun 13, 2012 | 06:41 AM
korizmo's Avatar
I dropped my engine with trans attached to a machine shop. They gave it back to me the same way 2 weeks later with all new parts that I purchased for them. Never let the machine shop purchase the parts. They will get you overpriced items. One item my machine shop got me cheaper was the oil pump, about 100 bucks cheaper than anywhere online. They charged me around 1200 for bore/assembly.
When including new timing/balance belt, oil pump, water pump, bearings, rods/pistons, engine gasket kit, head studs, fluids, and other small items that you want to replace when refereshing your engine.
The cost ends up being close to 4K
Old Jun 13, 2012 | 09:14 AM
rcheung's Avatar
The 4K is with you doing the labor of removal and re installation of the engine?
Old Jun 13, 2012 | 09:42 AM
TheBlade's Avatar
You could buy a built shortblock from MAP and send yours back as the core.
Old Jun 13, 2012 | 10:13 AM
korizmo's Avatar
Yeap. If you want to add in the cost of the hoist I had to purchase from harbor freight. Another 200.00
the shop next door to the machine shop wanted 1200.00 for engine removal and install thats why I decided to do it on my own
TxFAkuma
Past Winners / Entries
May 13, 2016 02:18 PM
night crawler
Mar 19, 2016 03:05 AM
philamthebest
Aug 6, 2010 01:36 PM
Turbojunkie
Northwest Region
11
Aug 20, 2009 01:22 PM
triple L
15
Aug 6, 2009 07:38 PM
