2011 X engine keep shutting off
Hi members
I'm stuck and trying to find out if any member hapen this before
I was crusing around 65~75 mph with AC on and I feeled I was loosing power.. soon as I hit the gas the RPM was dropping and engine shut off wjen the stopped.. was trying to start the car again it start normal and then ****s off in 3-5sec... I check the injector plugs and fuel lines there is no leak also with obd scanner does not reading nothing...
My car is heavy modded with cams, turbo,fuel system, and most of bolt ons....
Any suggestions??
Any suggestions??
Thx for the kind of awmsers!
Found the problem was on upgraded fuel pump line... Black-Ops fuel line was broken and had 2 rips.
And changed to new fuel line and she's back to the Road Strong again!!
Thanks very much to RRE and to Robert who came down from home to check my car
