Sponsored by:
Sponsored by: CARiD
meth / ethanol / alcohol kit
Old Jun 23, 2012 | 01:58 PM
Noe18's Avatar
i'm trying to learn more about aquamist kits. I'm guessing that the hfs-6 is best? but more important question to me is which is safer methanol ethanol or alcohol also not to mention where to but the items and how to mix 1 of the 3 with water
no bashing me on this, like i said i'm learning, so yes i search here and google
Old Jun 23, 2012 | 02:41 PM
Iowa999's Avatar
Your question doesn't make sense because methanol and ethanol are two forms of alcohol.
Old Jun 23, 2012 | 05:55 PM
Noe18's Avatar
^ I didn't know that's y I'm trying to get more info, school me. Methanol n ethanol is similar correct but ethanol is more like alcohol which actually u can drink up to a certain point also burns a blue. I'm thinking that ethanol is better to mix with water
Old Jun 23, 2012 | 07:38 PM
Kendogg's Avatar
Ignore him. He's like that. He doesnt play well with others. I think pretentious describes it best.
Old Jun 24, 2012 | 06:56 AM
Iowa999's Avatar
To me, the decision between methanol and ethanol comes down to why you are injecting something in the first place. If this is a back-up to your intercooler, then I would use a mix of methanol and water, because methanol has a high latent heat of vaporization than ethanol. If this is a power additive, instead, then use ethanol, because ethanol has more energy than methanol.
Personally, when I ran injection in a DSM, I just used blue windshield washer fluid and called it a day. Whatever you do, don't run tap water unless you have a reverse-osmosis softener. Salt-softened water and most public tab water will be too hard and your nozzle will clog very quickly.
ps. I have no input on the question of who should be ignored
Old Jun 25, 2012 | 05:11 AM
Wildcat Birdie's Avatar
Yes, Iowa can be what Kendogg called him, but more often than not, Iowa is also very correct in his comments. He points out stupidity (or not having knowledge in something) in others, and it is generally taken as very brash, but its just his personality. Iowa knows what he is talking about in almost every post I see of his. In this case, he is correct. There was not enough knowledge in the first post, so he pointed it out. He also finished with a second post giving a great answer using scientific facts between latent heat of vaporization as well as having more energy. So basically, long story short, Iowa is correct here. Depends on what the OP really wants to do with the kit.
Old Jun 26, 2012 | 06:59 AM
AWDXTCY's Avatar
Most people in my experience that still use methanol do so because E-85 is unavailable in their area...
Old Jun 26, 2012 | 07:33 AM
Iowa999's Avatar
While I have no idea why people do what they do (my day-job not-with-standing), I agree that E85 is a better way to go if it's consistently available in your area. For example, the rules under which I run allow either (or both) of E85 and water/alcohol injection, but no changes to intercoolers. Ten years ago, living in central PA, I added injection to the DSM and used a water/meth mix (i.e., blue windshield washer fluid). Now, here in Iowa, there's no question that I'd go with E85, instead.
Old Jun 26, 2012 | 03:19 PM
08gsrCoastie's Avatar
Is it as safe as e85 ?
Old Jun 27, 2012 | 06:07 AM
Noe18's Avatar
I live on staten island so E85 is no where near me at all, I want to buy aquamist kit and want to go with ethanol/water, where to buy ethanol?
Old Jun 27, 2012 | 10:26 AM
Noe18's Avatar
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Is this what I buy to mix it with water?
Old Jun 27, 2012 | 10:37 AM
Kracka's Avatar
https://www.evolutionm.net/forums/wa...ction-nos-173/
Old Nov 27, 2013 | 08:40 AM
bigmatt33's Avatar
I'm looking into maybe getting a water/methanol injection kit. I live in California so I have crappy 91 gas and my town doesn't have E85. I would probably use some kind of mixture of methanol or ethanol with water. I am looking at Snow, aqua mist, and AEM. What do you guys think?
My mods: TBE, intake, UICP, IC, 3port, custom tune. In the future I will likely upgrade the turbo. My car is putting out 330 WHP and 360 lbs of torque. I want to be closer to 400 with a better top end and not to much lag. I really enjoy that low end torque for daily driving.
Old Nov 27, 2013 | 09:51 AM
Iowa999's Avatar
One issue is whether the car is daily driven and/or how important is convenience to you? If you want this to be relatively simple, I'd just run (and tune for) windshield-washer fluid. Yeah, a fancier mix might be better, but the convenience of refilling the reservoir with every third tank of gas can't be beat. The only drawback is the annoying location of the reservoir on an X compared to, say, a 2G DSM.
Besides that, what I said a year ago with regard to methanol vs ethanol still stands. Methanol still has the higher latent heat; ethanol still has more energy in it.
Old Nov 28, 2013 | 10:57 AM
QuickShiftGSR's Avatar
I have never seen anyone spraying ethanol in their water/meth injection setups before. Likely because it doesn't remove heat from the air charge as well as methanol and water do.
