Sponsored by:
Sponsored by: CARiD
View Poll Results: Is this photo a teaser or a photochop?
It's a teaser ... and I want!
60.00%
It's a photochop ... and rather pathetic at that
40.00%
Voters: 15. You may not vote on this poll
teaser or photoshop?
Old Aug 10, 2012 | 12:33 PM
Iowa999's Avatar
15" Braid wheels and gravel tires on an Evo X.
Old Aug 10, 2012 | 12:46 PM
ugakirk's Avatar
Where is the "It's real, but I don't want it.."
Pretty cool for you rally guys, but I have no use for it. What brakes is that thing running?
Old Aug 10, 2012 | 12:48 PM
m0nkie's Avatar
does this guy use Evo to farm his land? lol
Old Aug 10, 2012 | 04:09 PM
EAGLE 5's Avatar
+1 Most likely real but with some kind of different brake setup then the stock Evo X brakes.
Old Aug 11, 2012 | 03:19 PM
Iowa999's Avatar
Wouldn't that give away the correct answer to the poll question....?
Old Aug 11, 2012 | 05:45 PM
Keith6110's Avatar
I wouldn't think these would clear the brembo's lol. Probably a pretty smooth ride though with all that tire.
Old Aug 11, 2012 | 08:13 PM
Prickuliar's Avatar
Wilwood makes a set of "rally brakes" for the fronts not too expensive eitherhttp://www.amsperformance.com/cart/A...Brake-Kit.html
Old Aug 11, 2012 | 08:18 PM
Iowa999's Avatar
The front is easy. Anyone can do the front. And for less than AMS asks for, as well. $1600 for the fronts only is nuts.
And, no, the ride would not be smoother ... assuming that the picture is for real. Gravel tires have rock-hard sidewalls. If you drove the same lousy road twice, once on 15" gravel tires and once on 18" R-S3s ... assuming that the picture is real, of course ... then the ride would be smoother on the latter.
Old Aug 13, 2012 | 09:22 AM
Iowa999's Avatar
Alright, I had my fun.
The picture is real. Ryan at ThompsonRacingFabrication.com now has front AND REAR kits to put 15" wheels on an Evo X. The fronts drop 14# per side, more than half of which is rotating, and the rears drop 4# per side. And this isn't using paper-thin rotors, either. These are meant for stage rally.
Braking distance on tarmac increased by about 9% using Wilwood's least-aggressive pads (which brought the car back to where a stock Evo 8/9 is, since the braking system on an X is so good). I'll do some more testing (when it stops raining) with the next step up pads in the front, because I know that the bias is a tad too much to the rear (on purpose, for low-grip situations). I just wanted to start with the least-aggressive pad for more modulation on gravel. But I also autocross, so I will try other combinations and say more later. But, man, the rotation with a little left-foot braking is wonderful.
Note: I would not only recommend these brakes for people who play in the dirt, but also for both drag-racers and autocrossers. Because the rotors are as big and thick as the brakes on a RalliArt, which is on the same line in the SP rules, they are legal for ASP, as well as SM.
Old Aug 13, 2012 | 10:01 AM
tkromer's Avatar
Price???
Old Aug 13, 2012 | 10:39 AM
Iowa999's Avatar
$950 for the fronts. $1400 for the rears. Or $2300 for everything. Included all the adapters and hoses, etc.
edit: I should have mentioned this before, for people who know why the rears on an X are such a pain: this kit retains the OE hand-brake. That's why it's legal in Prepared AWD (rallycrossing) and ASP (autocrossing).
