Sponsored by:
Sponsored by: CARiD
Weird RPM fluctuation
Old Aug 16, 2012 | 02:30 PM
lapoune's Avatar
Hi,
I have had this for some time now on my car and it's starting to bug me. The car drives fine but when I put the clutch pedal down the RPM will fluctuate (a lot, not like the other issues I've seen).
It mostly happens if I have the AC on, but sometimes it will do it even without.
Here's a video: http://tinypic.com/player.php?v=24lpt9u&s=6
If I have AC on it sometimes does it indefinitely like in the video (where I just put the clutch pedal down while driving at a steady 50kph to see if it would do it). But this also happens when coming to a red light for example where it will fluctuate for a couple seconds then go back to a stable idle.
Old Aug 16, 2012 | 02:46 PM
ikt's Avatar
ikt
Originally Posted by lapoune
Hi,
Do you have a cold air intake on there without a sheild? Because AC fan blows onto the air element and makes it fluctuate. If you don't, it's probably a vacuum leak where the line from the fuel pressure regulator goes to the intake manifold
Old Aug 16, 2012 | 03:00 PM
Maz's Avatar
Maz
I hope you figure it out man :/ I'm sure you'll find your answer here though GL
Old Aug 16, 2012 | 03:11 PM
TheBlade's Avatar
Old Aug 16, 2012 | 03:39 PM
lapoune's Avatar
I have the oem airbox with stock filter.
I zip tied the fpr hose as soon as I got the car too so it's ok.
I have a boost gauge and checked the hoses and they look fine too.
hope it's nothing serious
Old Aug 16, 2012 | 04:09 PM
ikt's Avatar
ikt
well, just looking might not help. You need to check for leaks. you can do this the old school way by spraying the vacuum lines with carb cleaner or starting fluid while it's running. If the engine suddenly revs, there's the leak.
Does the boost gauge show a fluctuation with the idle? Are you running a stock blow off valve? If the BOV was leaking it could let in unmetered air. How many miles?
Also check your fuel pump relay is the new one, check your plugs, fuel filter, fuel pressure and plug wires.
Old Aug 16, 2012 | 05:17 PM
lapoune's Avatar
I see I see. I'll look into all of this. But yeah the car is stock apart from a perrin catback + mil.spec cat. (the car did this before the exhaust change though).
And no fluctuation on the boost gauge. It move like 1 psi when the problem happens but normally it doesn't fluctuate at all.
Got 12 000 miles.
The weird thing is it seems to do it only when moving. If I press the clutch in and come to a complete stop it will stop fluctuating, but if I just press the clutch in at speed that's where the problem occurs...
Edit: my AFR gauge goes crazy though, goes from like 13.5 to 18 at each of the little revs you see on the video
Old Aug 17, 2012 | 06:04 PM
quicksevo's Avatar
I have a similar issue. You more than likely need a tune
Old Aug 20, 2012 | 11:57 AM
donzilla2004's Avatar
My 08 does it once in a while too. It seems to be a pretty common thing with a lot 10's. After it was tuned, it helped a little it happened less frequently.
Old Aug 20, 2012 | 12:59 PM
ikt's Avatar
ikt
Got 12 000 miles.
oh, you have an injector cutting out then, when it's spiking to 18 that means it's stuttering.
it should already have a tune, but even then it shouldn't be doing this
please tell me you guys all have the updated fuel pump relays
Old Aug 20, 2012 | 01:08 PM
EVO X 6950's Avatar
im guessing the maf sensor
this happened to me twice, once with the almighty hose on the IM and when my MAF sensor went
Old Aug 20, 2012 | 01:09 PM
ikt's Avatar
ikt
at 12k tho? I guess mine went at 55k
Old Aug 20, 2012 | 06:21 PM
EVO X 6950's Avatar
Mine went at 14.5k, yes I was shocked too
Old Aug 21, 2012 | 08:19 AM
lapoune's Avatar
I'm taking it to my dealership tomorrow so we'll see what they say.
I tried the vacuum leak test with carb cleaner and there wasn't any change in the idle.
It seems to have something to do with airflow since it only does it when the car is moving and the outside air is hot. It started doing this at the end of the summer but when autumn came the issue disappeared so I forgot about it.
Now in the mornings it won't do it since it's colder outside but near noon it comes back.
And I should have the newer fuel relays...my dealership changed them twice (from first black to blue ones to newer black ones)
Old Aug 22, 2012 | 02:11 PM
lapoune's Avatar
Just came back from the dealership they said they flashed something per TSB-12-13-002 and from the short drive to my house it looks like that fixed it.
