Sponsored by:
Sponsored by: CARiD
04 STi to EVO X
Old Aug 20, 2012 | 03:30 PM
ddawg1130's Avatar
Same power MR is faster 1/4 mile...
Most GSR owners can't do 0-60 times as fast as the car should be able to, where as in the MR anyone can do it...
MR will always be in the perfect gear at auto-x. Only downside to MR for auto-x is you can't left foot brake as it automatically slips the clutch when the break is applied.
But only real reason I replied is to correct people saying that redline in 4th is 112 or 116 mph, umm... that's just not true. It's way closer to 100. 5th is a cruising gear, but car doesn't fall flat on it's face when you shift up to 5th, it still pulls hard. 5th is actually a great gear for DDing. once you hit 50 just leave it in 5th unless you drop below 45. 3800 rpms at 80 is correct, it's not the quitest. Your choice in exhaust will obviously impact how much you can stand 5th on the highway.
Old Aug 20, 2012 | 03:35 PM
EvilRob's Avatar
Wow way to spread missinformation first you say we are wrong aboutt 4th topping out at 112-116 and then you sound like you just took a guess and said 100. People who run 1/4 have to shift into 5th past 112 mph as for the Mr thing again you are wrong stock times the gsr is always posting faster 0-60 and 1/4 mile times. Mr has limiter on first gear so you don't get to use all of the power once someone figures out how to bypass it then it might be faster.
Old Aug 20, 2012 | 04:47 PM
willyan1989's Avatar
The TPS limiter is removable awhile ago buddy.
Old Aug 20, 2012 | 07:56 PM
ihatefwd's Avatar
Hmmm maybe he is thinking stock???
Old Aug 20, 2012 | 08:09 PM
Pbayr0lla321's Avatar
I went from an 04' STi to the 2011 Evo X GSR. Both cars stage 2 and tuned. The Evo would walk my old STi in every aspect of the word. It took some getting used to going from a 6-speed to a 5-speed, but I love being able to feel the power through every gear of my evo, as opposed to shifting every 3 seconds with the Subaru. The difference between the two.. the Subaru was an ax murderer, you can thrash it, throw it in the mud, and make it home in time for dinner. The Evo is a surgeon. Precise, sharp, and makes it home before dinner was even in the oven. I think that's a pretty good analogy?
Old Aug 20, 2012 | 09:00 PM
teameditevo08's Avatar
From what ive heard the evo has alot more potential than the sti so imo who cares if its 5spd the car is a beast but your best bet is test drive and see for yourself
Old Aug 21, 2012 | 05:30 AM
Josh x's Avatar
Go test drive one, and see if you like it or not
Old Aug 21, 2012 | 05:31 AM
The Duke's Avatar
I was wondering about that. Does having a 5-speed in the EVO make mroe sense than the 6? But since the car makes most of the power up top, wouldn't you want to stay in the upper RPMs longer, or does the DI help provide enough power down low to reduce the need for a sixth gear?
Old Aug 21, 2012 | 05:53 AM
erald01's Avatar
it seems like you are really hung up on this 5spd vs 6spd...Go test drive the car and see for yourself, your 6spd STi idles only 200 rpm less than an Evo would at 70 mph, just like the 2006 Evo MRs 6spd do, its NOT that big of a difference. As long as the gearing is done properly 5spd vs 6 spd does not matter.
The only advantage I ever saw on a subi was the rwd based trans and drivetrain as opposed to the fwd on an Evo, other than that EVo dominates in every aspect, even the subaru guys know it. The only difference is who you want to be loyal to, and thats where the fights usually happen.
Old Aug 21, 2012 | 07:15 AM
Solarwater's Avatar
It was my car that he rode in after the autox on Sunday, I recently moved to Ohio, but still have NY plates.
My boost is tuned to 27 and tapers off to 21 when the turbo runs out. It spikes to 29 on spool. I only have a catback exhaust, and a lightweight flywheel right now, so it is def not built.
But back on topic, I test drove the new wrx and the sti when I was looking at getting a car, and they felt slow as dogs, when I drove the evo X, I fell in love with it, it just felt good.
I do wish i had a 6th gear just for cruise, but the 5 speed is fine, (I guess I've never owned a car with a 6 speed).
You know where my vote is .
Old Aug 21, 2012 | 07:51 AM
The Duke's Avatar
I was wondering why you had NY plates and were in effin Akron Ohio. I hoped to god you didn't make the trip to Akron just for that event from NY
When we went for that quick ride, were you going WOT? I'm not sure if the increased lag in my STi makes it "feel" faster, but it is nice feeling how quick the turbo spools in the X. Maybe I was expecting more, but it's just like mine. Tune and that's it.
Where throughout he rpm band does it peak to 29?
The suspension though, dear god was it sharp and precise.
Old Aug 21, 2012 | 09:46 AM
ddawg1130's Avatar
Sorry haven't done a pull up over 100 in a while, but I'm pretty damn certain it's not that high. Maybe I am wrong on that.
I never said the GSR wouldn't post faster 0-60 times, so try reading...
And I said equal power leves the MR will take the GSR in the 1/4 mile which just is true. If you don't believe me there's a best motoring video out there where they compare just that.
Old Aug 21, 2012 | 10:02 AM
johnnnyjeans's Avatar
you want the 5 speed. its nice. dont get the MR. and go redline cocktail.
Old Aug 21, 2012 | 11:54 AM
EvilRob's Avatar
I've heard of the show but I don't really watch it. Most my facts I'm posting from magazines/sites like autoblog, caranddriver, motortrend, insideline, and a few others. The fastest time for 1/4 mile and 0-60 that I have seen were set by a gsr. The gsr posted a 13.0 sec 1/4 mile and a 4.3 sec to 60.
Old Aug 21, 2012 | 12:08 PM
The Duke's Avatar
Is there any way to make the exhaust pitch higher? Seems like most want a lower pitch'd exhaust, but to me the car at 7K rpm doesn't particularly sound liek it.
