Dam Burning Smell!!!
It could be your tires or clutch though, both have distinctive smells. Whats it smell like?
Yeah I had a similar smell for the first 5k miles. The mechanic told me it was the assembly lube and chemicals they use, burning off. I stopped smelling it somewhere between 5-10k.
I do not have an Evo X but I've read other Evo X guys having issues with their aftermarket exhaust header being too close to the firewall so when the header heats up it can cause the material on the firewall to smell burnt and even catch on fire...Not sure if this pertains to your setup but something to keep in mind. I don't know how many exhaust manifolds allow the stock heat shield to be put back on but this was with the stock shield off...
Just what I've read on this forum...
Take look at your firewall by the exhaust header next time you pop your hood.
Smells almost like burning hair for me. Definitely not the clutch or tires. This is also my 3rd new car. I know of the smells when a car is new and burning off the lube and oils. This smell is not that. Plus I have never had those new car smells after a couple thousand of miles. Mine only smells when I get into boost so I assume it's the turbo. It's gross though.
You could have something else though, something close to your turbo/exhaust thats melting. My problem was pinpointing the smell, if I'd jump out and go under the hood no real area smelt like it more then the other - i assume you've tried this? Might give you a general location.
You have the stock exhaust? I will check mine tomorrow. The only problem with that is I would think if it was the cushion it would have a the small regularly. Mine only occurs when in hard acceleration.
I don't see what could be wrong with it and I do NOT want to take the car to the dealer unless I have to.
I'm just sitting in the car driving when I smell it. You don't have to put your nose anywhere because the cabin fills with the smell. The first time I really smelt it I accelerated hard to get on the highway. But I was pretty much going in a straight line. My foot wasn't on the clutch. I was in 4th gear. I floored it and then at around 5k I switched to 5th and cruised. Then the smell sat in.
I guess you kind of have to in Texass?
Thats why I wonder if the smell is just from a hot turbo since it's so freakin hot here or if it's boost leak or something. I would hope everything is ok on a stock car with less then 4k miles on it
Mine only smells if I get on the throttle. But the cabin starts to smell like...well I don't know what. Reminds me of hair dye or some kind of hair chemical. When I was younger my grandma use to take me with her when she would get her hair done. For some reason that is what the smell links to in my brain. Like old lady getting their hair done.
