Sponsored by:
Sponsored by: CARiD
Running on Low Boost?
Old Oct 5, 2012 | 06:12 PM
2011EvoXGSR's Avatar
So... don't know if this has been posted before, but I can't really seem to find an answer.
I have an FP black, tuned to 470whp/360wtq
I also have a AEM electronic boost controller...
Was wondering if I can turn down the boost all the way down to like 5psi. Would this hurt anything!?
I have no accessport btw.
Thanks guys!
Old Oct 5, 2012 | 06:27 PM
mrMTB's Avatar
Probably not. If I recall correctly the black ships with an 18lb wastegate. While you could turn your boost controller down below that, the wastegate will remain closed until the pressure overcomes the resistance of the spring.
Old Oct 5, 2012 | 06:51 PM
4B11AWD's Avatar
Why would you want it that low anyways? How much boost does Aaron have you on right now?
If you want a low boost map go back to English and have them create you a low boost map for like 20psi.
Old Oct 5, 2012 | 11:23 PM
Well, I wanted it low because I really don't need all that much power for just commuting. But it all make sense since the boost controller has a preset with the lowest boost at 18psi, then there's a 23psi or something and then the tune was at 27 psi which is basically my "full power".
I don't have an Accessport so I can't really change maps. Aaron directly tuned the ECU because he said he can get more power
Old Oct 6, 2012 | 06:49 AM
TheBlade's Avatar
My tuner couldn't get it to work, but rumor is Golden figured how to make Tephra's Mod work for on the fly map switching for OpenSource tunes for the '11 ecu. That could take care of the no AP and map switching.
Makes sense to have a low boost, commuter friendly map honestly. It's not like the street is a great place to run a car with a ton of power everyday.
Old Oct 6, 2012 | 08:31 AM
ravenjam's Avatar
Couldnt you just maintain your throttle position? If you dont want all that power, just dont squeeze.
Old Oct 6, 2012 | 11:50 AM
4B11AWD's Avatar
Its true, you won't hit 27psi unless at WOT. Most of the time daily driving I probably barely even hit boost, its usually in vacuum.
The only reason I see getting a low boost map is to a) keep EGT low b) maybe have it tuned where boost doesn't come on as soon (although don't really know anyone who wants b).
Old Jun 5, 2014 | 07:50 PM
yuriyz's Avatar
I think having a dual map tune is a great idea. One for dd and one for track
Old Jun 5, 2014 | 08:16 PM
JDZNate's Avatar
Veteran: Air Force
Why don't you just PM Aaron and ask him?
arpad
179
Feb 9, 2020 03:51 AM
Morne Reyneke
Feb 22, 2017 08:17 AM
cmoore
Feb 7, 2016 04:27 PM
sushtsi
Cobb AccessPORT
Dec 29, 2014 10:45 AM
DynoFlash
47
Jun 11, 2005 09:25 PM
