Sponsored by:
Sponsored by: CARiD
AEM A/F gauge stuck at 14.8???
Old Jun 3, 2014 | 06:35 PM
Pudge23's Avatar
Exactly what it says, it worked fine this AM but this PM on my way home I noticed it stopped working was locked at 14.8
Any ideas what it could be? Sensor, gauge? Wiring?
Any input would be great.
Old Jun 4, 2014 | 05:36 AM
MR. EVO MR's Avatar
Test the sensor.
Remove it, get a rag with a little fuel on it and wrap it around the sensor.
Is the sensor shows rich it's working, if it doesn't move time to replace the sensor.
Old Jun 4, 2014 | 04:27 PM
titotonto's Avatar
Could be the sensor or wiring. How old is it? Since it is cheap (maybe free), I would start by inspecting the wiring, especially close to the sensor (where it's likely to see a lot of heat).
Old Jun 4, 2014 | 05:29 PM
stiggysaurus's Avatar
Check your wiring
Old Jun 4, 2014 | 07:39 PM
05OrangeSS's Avatar
Yep check the wiring, or the connector first to make sure it's actually hooked up. Next test would to be the gas test mentioned. Only things that could be wrong. It's a good general rule of thumb to change out the sensor once a year for good safety measures.
Old Jun 4, 2014 | 07:40 PM
2slow4g63's Avatar
Check you wiring
Old Jun 5, 2014 | 09:54 AM
Omg AWD's Avatar
I had the same issue about a month ago.. it was the sensor.. i picked one up from extremepsi for like 60 bucks.. and good to go..
Old Jun 6, 2014 | 06:31 AM
BarmanBean's Avatar
I feel like I end up replacing my O2 sensors (wideband or otherwise) every couple years. They jsut go bad and replacing them is never the end of the world really.
Old Jun 6, 2014 | 07:29 AM
RZA's Avatar
RZA
AEM widebands suck and the sensors are garbage and inaccurate. I would buy a proper wideband like an NGK AFX which comes with a NTK sensor that is compatible with all types of fuels and will last years and years without issues
Just my $0.02
Old Jun 6, 2014 | 08:10 AM
Pudge23's Avatar
Thanks for the feedback! Ended up being a loose connection inside the gauge pod, somehow the connector dislodged itself. Back to normal now.
I will keep the other suggestions in mind if and when it starts acting up again.
Old Jun 6, 2014 | 09:59 AM
EvoX320GSR's Avatar
Just my $0.02
Since some of us may own an AEM gauge already. Does an NTK sensor fit or work with an AEM gauge! I have an AEM Gauge...
lemmonhead
Jun 18, 2025 01:51 PM
Insanity Evo
Jun 14, 2016 06:45 AM
Junkyardspecial
Aug 11, 2015 06:23 PM
ekinshuya
Jan 12, 2015 08:26 PM
