Sponsored by:
Sponsored by: CARiD
Need Help on Adjusting Steering Column Into car.[Pics]
Old Oct 15, 2012 | 06:13 PM
neogx's Avatar
Alright I bought a Steering column with everything on it. Just when i installed it the first time i didnt look at the angle sensor. And after i installed it I was having "AES OFF " and i had took it to the dealership and they told me it had to do with the angle sensor. So im looking for any info on installing it right. I have the tires straight and the shaft off
I dont know when the people took out the steering column off the other car if they moved the steering wheel around . So Im not sure which way or how many times i should be turning the the steering wheel to have it angled right. Should i be looking at the angle sensors window while turning the steering wheel? . It says this on the steering angle sensor [ Old steering angle sensor ]
Do i stop when i the arrows stop and i see this?
The thing is IM VERY scared of turning the steering wheel too many times and screwing up the Clock spring.... lol like i did the first time
Old Oct 15, 2012 | 07:56 PM
Johnr352's Avatar
If you do a search here or on the other forum you will find a how to on replacing some switches on your steering wheel. That document might help you sort out the column install as it does cover the sensors.
Otherwise, find a good shop.
tinkolby_25
Mar 7, 2016 07:15 PM
Evo2H8
Aug 20, 2013 10:06 AM
Anubis18
Feb 12, 2013 05:28 PM
ninekrevs
Apr 23, 2012 11:02 PM
sargeek1975
Mid-Atlantic Region
11
Sep 19, 2010 08:28 PM
