Sponsored by:
Sponsored by: CARiD
Gauge mounting on Steering Column
Old Nov 19, 2012 | 12:11 AM
HDGamer's Avatar
Hey guys, I need some ideas on how to mount my single gauge like in this picture.
What's the best way to go about mounting it in that area?
Old Nov 19, 2012 | 04:50 AM
kzlflash's Avatar
Do you mean what gauge cup you should buy? Or mounting methods?
Either way, the way I did it was I purchased the Autometer 2204 gauge cup, and just mounted it on that same exact position you see, with double sided 3m industrial tape. They give you screws to screw into the steering column, but I didn't feel like putting holes on the cover.
Old Nov 19, 2012 | 05:29 AM
JReid's Avatar
You could just screw it in as stated above or they actually make steering column covers that can be a direct replacement for the OEM and hold a gauge. I believe that steering column cover is pretty cheap OEM, so you could pick one up down the road if you want to remove the gauges without showing holes.
Old Nov 19, 2012 | 06:40 AM
TheBlade's Avatar
Hit up SRToad4 on here, his install is just like that (but with two). It looks amazing.
Old Nov 19, 2012 | 06:47 AM
EAGLE 5's Avatar
Does he have an how-to / writeup or just pictures?
Also stack boost gauge? Nice!
Old Nov 19, 2012 | 07:04 AM
TheBlade's Avatar
He doesn't have a write-up per say, but he's a nice guy and I bet could do a write-up or give some pointers while attaching them on the far sides of the column. Here was his recent thread:
https://www.evolutionm.net/forums/ev...uge-setup.html
Old Nov 19, 2012 | 07:52 AM
EAGLE 5's Avatar
Thanks I'll have a look.
And because of this thread I'm now seriously considering the Stack mechanical boost gauge over the Garrett I was dead set on...
Jeez.
Old Nov 19, 2012 | 08:10 AM
Johnr352's Avatar
Well, first I think you need to buy some gas... We had a couple of gauges mounted similarly and I'll admit, they were a bit distracting. I suggest, before a permanent solution, you experiment a bit with some tape to hold it in place. Ultimately we removed them and moved them to the vent left of where the radio is located. It's a racecar, so the application is different, but think about it a bit before you start drilling.
Old Nov 19, 2012 | 09:48 AM
TheBlade's Avatar
Although I love Toad's install, I'm with John.
For my X, I have them on the pillar. I like being able to see my cluster without anything on the column. This is one of those times I *really* miss my Subaru with the 3gauge clock-pod setup.
I can't wait to get and install a WB AFR in the next week or so. I put a distribution block together when I did the boost gauge, so it should be super easy
EAGLE 5's Avatar
I personally would place the boost gauge on the column by the empty "space" between 0 and 9K on the tach.
Makes more sense to me I'd reserve that space for some other kind of gauge like an Aeroforce multimeter gauge.
Old Nov 19, 2012 | 11:16 AM
Johnr352's Avatar
Yes, I like this idea.
Truth is I want to redo the whole thing when we shift to an AIM cluster. I know, it sounds crazy, but I wold rather have simple lights, like a knock light, for boost, oil temp and pressure, trans temp, (and since it is my fantasy - I want tire pressure and tire temps in car) as long as we have the ability to set the values as to when the lights would illuminate. Gauges are hard to read on the track, especially if they are jumping around, so you really have to decide what's valuable, not just what looks cool. Lights would, at least, tell me what's at or near a threshold.
Old Nov 19, 2012 | 11:56 AM
EAGLE 5's Avatar
That's one of my options. The other is put the boost where I suggested and a single A pillar pod for the Aeroforce gauge like that Rexspeed single or if they ever make an LHD version the Monster Sport which looks AWESOME.
Still up in the air between Garrett Boost gauge or the Stack. I like the color scheme of the Stack which matches the factory perefctly but the position of the needles on the Garrett looks closest to the factory and I guess it wouldn't be too off to have a red needle for boost.
Choices...
Old Nov 19, 2012 | 08:22 PM
A769's Avatar
Got a standard gauge cup. Worked just fine.
Old Nov 20, 2012 | 02:22 PM
TheBlade's Avatar
Yeah it's why I went with just a two gauge a-pillar. Boost and WB AFR. Other than that I want a monitoring system that will just throw a big red light in my face with knock, low oil press, high oil temp, etc.
If any of those throw the warning light, I just want to find a place to pull over, and then start looking at gauges or logs.
Old Nov 21, 2012 | 10:58 AM
EAGLE 5's Avatar
Originally Posted by pgpunkguy
IMO, this position would obstruct view to the main screen (in the center). i put my boost gauge between 0 and 180 on the speedo (as far back as it would go). it only slightly obstructs the brightness button of the dash...
once i get my WB, i'll probably go with a dual pod a-pillar setup...
in the end, experiment and do whatever makes you happy...
Interesting you'd say that, I saw my choice for a setup and it didn't obstruct anything you could even still read the temp gauge without a problem.
I think its based on how you mount the gauges in relation to how you keep the steering wheel and even your own height - line of sight. Also the size of the gauge itself makes a big difference 52mm vs 60mm.
I much prefer the Boost gauge to be with the tach because I had one on my STi away from the "action" of the tach and I was constantly distracted by it. By the tach I'd look at it for reference but I wouldn't be drawn to it.
