Sponsored by:
Sponsored by: CARiD
T-Bolt Clamps How tight?
Old Nov 22, 2012 | 10:23 PM
HDGamer's Avatar
How tight should the T-bolt clamps be on the intercooler piping?
Old Nov 22, 2012 | 10:35 PM
HDGamer's Avatar
Please note that I have the ETS piping, which I believe is steel. So I'm guessing I can just tighten it hard?
(Pipe wont bed because its not aluminum)
Old Nov 22, 2012 | 10:39 PM
lucke24's Avatar
Tight enough not to spin when you grab it and try to rotate it.
Old Nov 22, 2012 | 10:46 PM
k_sheanh91's Avatar
tight enough to where you cant tighten it with one hand on the ratchet
Old Nov 23, 2012 | 02:28 AM
Optiblue's Avatar
It almost seems like it turns forever eh? As long as it feels tight on the actual pipe its fine.
Old Nov 23, 2012 | 08:18 AM
beetle_orange's Avatar
Gotta agree with optiblue here, when I was doing my uicp it seemed it was turning forever.
Old Nov 23, 2012 | 03:02 PM
HDGamer's Avatar
Yeah mine seemed to turn forever. But since the ETS pipes are steel and not aluminum I went ahead and tightened it until I couldn't do it with 1 hand anymore
Old Nov 23, 2012 | 03:09 PM
ETS Michael's Avatar
Your good! The guys here are crazy they use an air ratchet lol.
Old Nov 23, 2012 | 03:24 PM
dldjros69's Avatar
^i wish this was facebook and i could like that comment! Im doing my Ets intercooler install tomorrow. Thanks for the advice.
Old Nov 23, 2012 | 03:28 PM
ezzey's Avatar
tighten, boost leak test, results
boost leak test is fairly easy, so once you're all good to go, and you finished installing anything that has to do with pipes, or anything that can create a boost leak, i do a test. Before you get tuned, boost leak test. Changing uicp, or licp, boost leak, etc.
May sound like a pain in the ***, but sure beats NOT loosing power, and not blowing hoses on the freeway.
dave
Old Nov 23, 2012 | 03:33 PM
10isace's Avatar
I know this is about IC piping, but I over tightened a brand new FullBlown Throttle body. I only used one hand and it snapped the TB inlet. It's pretty much useless now until I weld on a small 3" aluminum pipe with a lip. I boost leak test, tighten clamps where leaks were, and repeat. However, be careful on aluminum, especially cast aluminum.
Old Nov 23, 2012 | 06:41 PM
dldjros69's Avatar
How do u perform a boost leak test?
Old Nov 23, 2012 | 07:32 PM
uhhhson's Avatar
Just go a half turn past bad ***
JonGonzo
Apr 18, 2014 06:44 AM
Eric Lyublinsky
Sep 14, 2013 12:26 PM
taylorgang
Sep 24, 2011 08:35 PM
R0ME0
Jun 18, 2009 11:55 AM
Cajun Power
Apr 13, 2006 10:40 PM
