Sponsored by:
Sponsored by: CARiD
what to cover when cleaning engine bay?
Old Dec 1, 2012 | 08:59 PM
GsrJake's Avatar
What exactly all do you cover in the engine bay? All I know of is the intake, alternator, battery, and turbo? Ill probably be spraying it down with a high pressure washer or just a hose then using scrubbing bubbles.
Old Dec 1, 2012 | 09:07 PM
TheBlade's Avatar
Well I would take the engine cover off and then plastic cover the coil packs for sure. Like you said Alternator and there's no batter (that's in the trunk), but the big distribution block, ecu and fusebox 100%.
I would cover the filter and avoid hitting the MAF sensor plastic. Probably avoid the pigtails to the fuel injectors too
Old Dec 1, 2012 | 09:18 PM
GsrJake's Avatar
lol yeah idk why I said battery, but ok ill make sure to get all those covered.
Old Dec 2, 2012 | 01:40 AM
Kouki Monster's Avatar
Yeah intake, alternator, and battery are usually the only things you have to worry about..but anything extra wouldn't hurt
Old Dec 2, 2012 | 05:15 AM
whiteEvo08Y's Avatar
Everytime i want to clean the engine bay i get scared. Heard too many bad story's when doing it. But make sure you cover everything(Parts you already said) and don't use alot of pressure when cleaning it with water, Or just use hose a regular water hose is the best thing to use. Also dont point the hose to close to any parts/Wires in the engine bay just so you don't cause any problems for yourself.
Old Dec 2, 2012 | 08:09 AM
akemi27's Avatar
Why are detailing q's in 'general'?
Old Dec 2, 2012 | 10:45 AM
GsrJake's Avatar
Yeah ima gonna be covering up alot of things just to be safe
Old Dec 2, 2012 | 03:04 PM
Fishstix's Avatar
I've never sprayed my engine bay. Just use a damp cloth and you're good to go!
Old Dec 2, 2012 | 04:33 PM
GsrJake's Avatar
I have a lot of dirty hard to reach spots:/
Old Dec 4, 2012 | 04:10 PM
bmxking45's Avatar
I always hose off my engine bay....never had any problems. Water gets in there regardless. I do it after the car has come up to temp....turn it off and then hose it down. The engine heat helps to evaporate all the water a bit quicker. I wouldnt worry about it. As for what I would cover....only the intake filter if you have one. If you are OEM then you should be good to go!
HOLLA!!
Old Dec 4, 2012 | 05:34 PM
jdmEviL8's Avatar
simple green, microfiber cloths, and tooth brushes. my ish looks new after 40k miles
Old Dec 5, 2012 | 03:08 AM
armysoldier1073's Avatar
I've always hosed engine, sometimes with power washer. All I've ever covered was the air filter since it is open type. If your on factory air box, maybe cover inlet. Let your motor cool before you go putting water on it though. Something cant handle rapid cooling down. I've never had any issues. If your first time make sure your oil cap, coils are all properly secured and you'll be fine. If the motor components weren't able to withstand some water, we'd have sealed engine bays. I mean ask the rally guys here how wet their motors get at times. They are still running fine. I'm not saying submerse engine bay in lake and start scrubbing either.
Old Dec 5, 2012 | 07:02 AM
slebo3213's Avatar
From the other forum:
http://www.youtube.com/watch?feature...&v=N-_8-Vm2Xek
Lot's of evidence that you don't need to cover anything if you're stock.
Old Dec 5, 2012 | 08:57 AM
GsrJake's Avatar
Damn lol I won't be going that crazy but thanks!
Old Dec 10, 2012 | 07:35 PM
khmerguyx's Avatar
Yea thats nice and a fast way to clean it but ill be too scared to do that lol
