Sponsored by:
Sponsored by: CARiD
Evo X power/torque limit - stock block/trans
Old Jan 9, 2013 | 11:37 PM
errdisab1e's Avatar
On a stock Evo X block and GSR transmission, I've read/heard suggestions that the "safe" limit should be no more than 400whp / 360wftlb. What I'd like to know, which dyno is that based on (mustang, dynapack, dynojet) and on which pump gas (91/93)?
I couldn't find a thread that covers this via search/google. Please link me if it already exists.
Thank you
Old Jan 10, 2013 | 04:10 AM
FastAttack's Avatar
eh no..
HP number is above 500.. tq above 400 kills stock blocks , tq kills our block not the HP.
Second is that the number is an avg amongst all of the our brave testers that have pushed the block beyond its limits , this of course is a multitidue of different dyno's and even virtual dyno's.
91/93 octane well again it depends on the tuner , conditions , etc. But most would agree the numbers on 91 are limited to how much boost you can run , as they can get knock at earlier power levels due to the **** poor gas.
Again, the numbers are just well, numbers, I honestly would not be looking at what peak hp/tq I can make , but what power level my tuner recommends based on the dyno he/she will be using.
Just food for thought.
Old Jan 10, 2013 | 05:08 AM
ugakirk's Avatar
Well, like ^^ said, you can get up to high HP as long as you keep the torque fairly low. A lot of guys are running like 460/360 and have no issues. Once you start getting in the 370-380 wtq range, it's getting a little risky- it may still be perfectly safe.. but you are def running a lot higher risk. People have done it though, although some blow at 320 too..
It really just has to do with how good of a tuner you have.
Old Jan 10, 2013 | 05:21 AM
Johnr352's Avatar
I think you have to do more research on this as there are a ton of threads that discuss HP and TQ limits. uga has it right though, it is highly dependent on the tuner, how the car is driven etc. I have heard of cars popping with low numbers like 360-375 tq and then others doing considerably better, all on stock internals.
You ask about the transmission too. The tranny is pretty stout and can hold quite a bit of power though seems to struggle with anything over 8500-9000 rpm.
Old Jan 10, 2013 | 11:08 AM
Kracka's Avatar
Daily-driven, 51k miles, stock clutch
These cars are very stout if you treat them right.
Old Jan 10, 2013 | 12:34 PM
errdisab1e's Avatar
Thanks guys for the info, clarification and real world reference.. great graph Kracka
Old Jan 10, 2013 | 12:44 PM
TheBlade's Avatar
If you look under builds you can see his entire build with exact parts (and parts he's tested and moved on without).
Old Jan 10, 2013 | 12:52 PM
Kracka's Avatar
https://www.evolutionm.net/forums/al...er-gheyer.html
Old Jan 16, 2013 | 11:30 AM
Thatotherguy's Avatar
How long have you had the ef2.5 on your car?
Old Jan 16, 2013 | 11:35 AM
Kracka's Avatar
EF2.5 has been on for roughly 2k miles so far, but more than half the miles on the car have been with an aftermarket turbo making 400+ WHP.
Old Jan 16, 2013 | 11:50 AM
GsrJake's Avatar
I know I few people running e85 stuck turbo makin 400whtq+ on 29 psi
Old Jan 16, 2013 | 12:25 PM
Robevo RS's Avatar
My transmission got a lots of abuse since 2008. And still running strong so as the ACD and the front of the car.
The rods are weak not the block.
Old Jan 16, 2013 | 01:54 PM
TheBlade's Avatar
This is my impression of what OE rods and rod-bolts are made of
Old Jan 16, 2013 | 03:06 PM
candymanjl's Avatar
Ha ha, that's funny.
Good info guys!
Who has a good rep as far as mail order tunes these days? I'm just looking for something simple to start, intake and tune.
Old Jan 17, 2013 | 05:58 AM
Kracka's Avatar
Bakaunchi and Razorlab are just about the only E-tuners that I would trust with my personal car. They aren't mail-order though, you'll email them logs and they'll email you back tunes. The days of actually mailing your ECU somewhere to get bench-flashed are loooooooong gone.
