Sponsored by:
Sponsored by: CARiD
Just about to hit 3,000 Miles
Old Feb 20, 2013 | 03:48 PM
vegittoss15's Avatar
engine off, but key in so you see the different menu options. On the service interval one, hold the button down until the wrench blinks and then press it again.
Old Feb 20, 2013 | 03:58 PM
jwongx27's Avatar
^^ okay thank you very much
Old Feb 20, 2013 | 06:29 PM
tellme718's Avatar
Clearly you are referring to a GSR
Old Feb 20, 2013 | 06:39 PM
apagan01's Avatar
Old Feb 21, 2013 | 07:34 AM
NGRLancer's Avatar
I do check ups ever 10000 miles and oil changes ever 3000 miles... If your engine light is on then get it checked out... Better safe then sorry
Old Feb 21, 2013 | 07:37 AM
dawidevo's Avatar
i do lil check ups every oil change
exackly better safe than sorry
Old Feb 21, 2013 | 07:44 AM
tellme718's Avatar
That's what I mean. What do guys check out?
Old Feb 21, 2013 | 07:50 AM
dawidevo's Avatar
all fluids visual inspection on all vacuum hoses if non is off look under the engine if any oil leak ..... you will figure it out
Old Feb 21, 2013 | 08:18 AM
ugakirk's Avatar
Why wouldn't that apply to the MR as well? I mean, unless you have the Navi I would assume you would use the same procedure.. Well, unless you have the FAST key, then you don't have to actually stick the key in.. Besides that, it should be the same..
With the Navi, I'm sure you could just adjust it from there, but not all MRs have it.
Old Feb 21, 2013 | 02:02 PM
tellme718's Avatar
Exactly what I said. Your referring to the GSR. Never said it can't be done on the MR. I'm just saying clearly the process on the MR is different especially with Nav.
Old Feb 21, 2013 | 03:24 PM
tellme718's Avatar
Repost 10char
Old Feb 21, 2013 | 04:02 PM
Leezon's Avatar
The service light has nothing to do with the navi.
What was previously said is exactly the same for the MR
Old Feb 21, 2013 | 04:40 PM
tellme718's Avatar
Good info.
Old Feb 21, 2013 | 11:02 PM
cjs_evoxgsr's Avatar
id check for dead animals in the engine bay. what more do you want? check everything if you want.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
