Sponsored by:
Sponsored by: CARiD
Just about to hit 3,000 Miles
Old Feb 19, 2013 | 08:08 PM
tellme718's Avatar
Already getting the maintenance light.
Anyone recommend any other procedures besides an oil change for my 2013 MR?
Old Feb 19, 2013 | 09:08 PM
cjs_evoxgsr's Avatar
U didn't get a owners manual?
Old Feb 19, 2013 | 09:22 PM
Windforce18's Avatar
I rotate my tires with my oil changes.
Old Feb 20, 2013 | 05:09 AM
tellme718's Avatar
I figured someone would be kind enough to say this.
Old Feb 20, 2013 | 06:10 AM
Kracka's Avatar
READ READ READ the owners manual, Mitsubishi was kind enough to give it to you for a reason.
Old Feb 20, 2013 | 06:26 AM
YUT0351's Avatar
There aren't that many services needed at 3000 miles. ^^^ what he said. Read the manual. if you really wanted to you could change the cabin air filter. But that's about all for the first few thousand miles. If your made of money you could do a tranny flush to get rid of the "break in" tid bits in the sst. But its not needed. If you go to the dealership for service they will recommend things to you.
Old Feb 20, 2013 | 11:30 AM
ugakirk's Avatar
Just an oil change.
Old Feb 20, 2013 | 11:32 AM
reggae4k's Avatar
use synthetic oil btw
Old Feb 20, 2013 | 11:33 AM
momostallion's Avatar
new paint job required at 3,000 miles.
Old Feb 20, 2013 | 11:58 AM
tellme718's Avatar
Guys, guys guys I'm asking from experienced X owners what things should I keep an eye out for now during the first 3k miles. Obviously I can always get the bare minimum from the OM. There has to be other things some of you know I should be on top of. If you can't think of anything...dont post.
Old Feb 20, 2013 | 12:27 PM
vegittoss15's Avatar
Get the upgraded fpr as well.
Old Feb 20, 2013 | 01:21 PM
►EvolutionX◄'s Avatar
-Rotate tires
-Change oil -SYN OIL
-Check Air Filter / Cabin air filter if you live in a dirty area
-Inspect all fluid levels
-Get your alignment checked if you want to make sure you're not going to burn up your tires
-Have your CV-boots checked for leaks...
.. I think that's it
Old Feb 20, 2013 | 01:23 PM
ugakirk's Avatar
There really isn't much.. Change the oil, check the fluids I guess, you could ziptie the fpr hose, and check or change the fuel pump relay. There really isn't that much to do at 3k unless you want to do something like change all the drivetrain fluids.. Which there is no need at 3k.
Old Feb 20, 2013 | 01:31 PM
Tsensational's Avatar
3k on any car, especially newer cars really dont ask for much. You can do all of the above and check your brakes for whatever you feel like but anything that is wrong probably would have showed itself already. Now 30k, that's another matter.
Old Feb 20, 2013 | 02:23 PM
jwongx27's Avatar
i dont like taking mine to dealer ship so how do u reset the service stuff?
i did my oil change at 1k miles
and almost at 2.2k miles il be doing another oil change at 2.5k with vr1 oil and oem filter
