Sponsored by:
Sponsored by: CARiD
Electrical and ECU problems maybe?
Old Feb 25, 2013 | 08:19 AM
aceboogX's Avatar
So i am driving a 2008 evo X GSR.
Recently my battery had died and took about 2 weeks for me to order the new redtop that is currently in
Problems:
-"!" check light comes on and off but gives me no faults
- ABS check light kicks on then goes off in about a 20 minute drive happens about 4-5 times but only for a second and goes away
-alternator fluctuates voltage while driving anywhere from 14-16.9V
-alternator at idle fluctuates from 13.5-14.4v all measures from my turbo timer
Now right now the temp is ridiculous somewhere between 20-30F but the car is a in a garage overnight till i drive to work.
My brakes have barely 1k on them and i have super blue racing fluid right now fluid level are all good.
I have gone through numerous threads and to no availability anything that combines what i have going on or individually not the same way. i have seen in one of the forums that due to extreme cold weather places replacement of certain fuses need to be done. I have already changed my fuel pump relay for it stuttering in the spring but i wondering if changing the relays would help all of these problems or if anyone else has had these problems.
please and thank you!
Old Feb 26, 2013 | 06:36 AM
aceboogX's Avatar
tested my battery and alternator and all good.....magically after i did all that changed my plugs and oil the drive home didn't get anything...however it is warmer out now.....anyone else having/had these problems?
Old Mar 1, 2013 | 02:00 PM
AIM WO4's Avatar
I had an ABS module go on a Saab that began that way.
Old Mar 1, 2013 | 03:55 PM
Johnr352's Avatar
I think you have a ground issue. Possibly when you first installed your new battery. Tests fine when the car is in the garage but a connection is not tight and, when driven, the vibrations cause intermittent grounding problems such that your systems get nutty. Check those connections.
Old Mar 2, 2013 | 12:32 PM
nerdbotSKRA's Avatar
I helped a coworker yesterday with her dodge caliber, she was having similar issues with the same dash lights (plus bucking during acceleration). First thing I checked were the battery terminals and I could pull the negative connector off with my pinky, I second the possibility of a grounding issue. The same thing happened with my 04 ralliart as well (broken positive connector)
Old Mar 3, 2013 | 12:01 AM
aceboogX's Avatar
ground were all checked terminals are tight. Funny thing is now that its getting warm its not happening as often or yesterday didn't happen at all. Well i plan on changing all my ground wires out on the car anyways hopefully if it is the problem somewhere it'll fix it.
Old Mar 5, 2013 | 10:42 AM
ikt's Avatar
ikt
metal shrinks when it's cold
Old Mar 31, 2020 | 10:58 AM
Jody Breeze's Avatar
Problems:
Did you end up finding the issue?
Im having the same problems.
I replaced the battery and the alternator. All of my grounds are fine.
I have just ordered a used ECU to test that. I believe that’s where the weird voltages are coming from.
2011 Evo X GSR.
dredman1
Lancer Troubleshooting
Sep 12, 2015 10:06 AM
blowngasket
Jul 1, 2015 09:16 AM
JonGonzo
Jan 15, 2014 01:58 PM
HN7
Sep 5, 2011 01:15 PM
theunfrailhale
Feb 8, 2011 01:16 PM
