Sponsored by:
Sponsored by: CARiD
help me find oil leak
Old Mar 5, 2013 | 02:50 PM
lapof's Avatar
Some times ago my car started to consume oil, not much but depending how i drive it could get to 1 quart per 3000 miles. I have nerver observed smokes in the exhaust and at that time i checked the spark plugs which were fine.
Recently I started to smell burning oil after a long highway drive, coming to a stop. so i investigated a little bit more and found that I I have some oil leaking on the transfer case and on the downpipe.
Removing the heat shield i have tried to take some pics but there is not a lot a room!
After reading through the forums, i think it might be the turbo oil return/supply line leaking. But how did the oil got that far?
Any clue or advice on this one?
Old Mar 5, 2013 | 03:18 PM
Johnr352's Avatar
It's hard to tell from the pictures but sorta looks like you are right. I presume you can't get in there to check the oil supply line? I suspect you are going to need to start pulling this apart to sort this out.
Old Mar 5, 2013 | 03:33 PM
meckert's Avatar
looks like the oil drain pipe---try and tighten the nuts--
Old Mar 6, 2013 | 02:37 PM
lapof's Avatar
thanks for input, I will try to tighten the nuts...
I will probably take it to the dealer to have it checked, but I wanted to source the problem before. Just to be sure they are not bull****ting me...
Lukelis
Oct 5, 2014 05:06 PM
RalliartN
Oct 2, 2014 06:02 PM
Pale Horse
38
Oct 21, 2013 11:46 PM
RoumKoTeam
For Sale - Cars For Sale
16
Apr 3, 2013 09:43 AM
kamakazy_kid
15
Feb 3, 2013 10:47 PM
