Sponsored by:
Sponsored by: CARiD
Whine noise when i accelerate
Old Mar 21, 2013 | 07:33 PM
  #31
mshilto89's Avatar
Originally Posted by rkelley
If your nervous about it, get some diaqueen LSD gear oil, drain, level the car and use the overfill method to fill the t-case. Then drive around for 10 minutes and pull the fill plug with the car level to check the fluid level. The t- case holds about 0.8 L of fluid.
I'm not really sure how to. I know there are some how to's online but I get a bit nervous when doing my own maintenance. I change my oil and everything, even changed out the tranny fluid when I first got it, but I'm not to sure about how to drain the fluids on the rest of the car like the t-case, diffs, and so on.
Old Mar 21, 2013 | 07:35 PM
  #32
rkelley's Avatar
Same drain and fill. No bleeding required on the t-case. If you did your transmission, the t-case should be cake
Old Mar 21, 2013 | 07:48 PM
  #33
Jagdeep.Kumar's Avatar
I have the same thing but mine is loud and comes from the right back of car i think my pump is about to die or my diff
Old Mar 21, 2013 | 07:53 PM
  #34
rkelley's Avatar
Sounds like the torque transfer side of your rear diff
jrsimon27
Lancer Engine Tech
25
Mar 27, 2018 01:40 PM
eddy5201314
Dec 4, 2016 06:51 PM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
knucklez
13
Aug 21, 2012 11:08 AM
LtownEvo
11
Aug 13, 2012 07:11 AM
