Sponsored by:
Sponsored by: CARiD
HELP idol searching like crazy! and boost hesitation
Old Mar 31, 2013 | 08:29 AM
GSREVOx's Avatar
i have an 08 evo x gsr, when i accelerate hard, when the turbo starts to spool it sounds like a kazoo, very weird noise, it goes away once its fully spooled. i recently got an accessport and tuned the car with a stage 1 ots map from cobb, for a complety stock car like mine, it was good for the first day but when i was driving it tonight i would go in to boost and it would hesitate while spooling but once fully spooled it pulled hard with no problems. also the car is idol searching like crazy, sounds cammed, but its not, car is 100% stock besides the accessport and after tonight i put it back to stock tune, the car now pulls fine with no hesitation but it when spooling the turbo sounds like a kazoo at least i think its the turbo, i could be wrong, and its still idol searching like crazy! HELP HELP HELPPP
Old Mar 31, 2013 | 08:39 AM
H Jensen's Avatar
Check for a vacuume leak. Also there is a hose on the left side of the intake manifold make sure it is still connected. Zip tie it if it hasn't been done already.
Old Mar 31, 2013 | 12:44 PM
GSREVOx's Avatar
thankyou so much man! i go look at the intake mani and that hose was popped off haha
Old Mar 31, 2013 | 01:07 PM
fabcas311's Avatar
Nice!.. But did u mean idle?? Hehehehe
Old Mar 31, 2013 | 03:18 PM
GSREVOx's Avatar
yeah im a bad speller, thanks man
Old Apr 1, 2013 | 12:36 AM
Frogstofall's Avatar
One other thing is to make sure you have updated your fuel pump relay. You would not believe the difference it makes if its busted (sounds like a baby rattle). I believe the correct part number for the updated one is MR122409.
Old Apr 1, 2013 | 05:40 AM
Veronica's Avatar
Wait, what? Gently shake a known/good relay. It should rattle too. Inside is a metal arm with a spring that makes/breaks contact... Usually when they fail it is in wiring of the electric coil that energizes and pulls the metal arm down - no rattle test would detect that failure.
If a realy did not rattle - i would suspect it...
Please correct me if i am wrong - i would not want people pulling relays and replacing all the 'rattlers'...
Old Apr 1, 2013 | 11:30 AM
ikt's Avatar
ikt
Originally Posted by veronica
wait, what? Gently shake a known/good relay. It should rattle too. Inside is a metal arm with a spring that makes/breaks contact... Usually when they fail it is in wiring of the electric coil that energizes and pulls the metal arm down - no rattle test would detect that failure.
i will fight you and that is no lie
Old Oct 18, 2015 | 08:24 PM
alfredoaal's Avatar
Hello, do you remember which hose was? I'm having a very similar problem after a cobb stage 1 reflash, my car has a lot of hesitation.
FX11
23
Mar 23, 2021 11:45 PM
sexydexy_evo4
Sep 28, 2016 08:39 AM
ajkevo8
Feb 20, 2016 03:59 PM
bossmangunit
Jan 24, 2016 01:45 PM
Alek Idol
Nov 21, 2015 01:06 PM
