Sponsored by:
Sponsored by: CARiD
resonator delete?
Old Apr 5, 2013 | 11:38 AM
hakcin's Avatar
resonator delete?
On my car i have the tomie expreme ti exhaust which is only catback exhaust
im sure many of you probablly know this
but my question is, is it posible to do just a resonator delete and replace it with the same diameter pipe
i only ask this cause i would like to keep the tomei exhaust but would like the car to be louder.
Old Apr 5, 2013 | 12:46 PM
Ev0ikon's Avatar
Remove catback altogether = LOUDER!
And to answer your question, yes you could cut and weld anything. Just expect to pay a bit more to weld Ti.
Old Apr 5, 2013 | 03:02 PM
Iowa999's Avatar
Yes, you can.
And now the thread will continue for 20 more posts while we debate whether you want to do this.
Old Apr 5, 2013 | 07:04 PM
MannyRamirez's Avatar
Thinking about doing this to with my cat back exhaust does it make it that much louder? Have any of you guys done this?
Old Apr 5, 2013 | 10:03 PM
davey111483's Avatar
Put a test pipe on if you want it louder.
Old Apr 5, 2013 | 11:21 PM
Smile
Can you recommend any test pipes or are they all pretty much the same?
Old Apr 6, 2013 | 08:29 AM
GsrJake's Avatar
I'm doing this with my Cnt dual exhaus, I only have one little muffler on my whole set up near the end that I'm getting cut out for 3" piping
Old Apr 6, 2013 | 08:38 AM
Alpha X's Avatar
ETS
http://www.extremeturbosystems.com/E...Test-Pipe.html
Old Apr 6, 2013 | 08:56 AM
Cool thanks man
Old Apr 6, 2013 | 01:33 PM
matt c's Avatar
Any test pipe will work as long as it has the bend in it. I personally have a tomei test pipe on a tomei expreme ti and it fits like a glove but im pretty sure the ets and so on will fit fine.
Old Apr 9, 2013 | 10:20 AM
elim0's Avatar
i wasnt aware the tomei expreme ti had a resonator ?
Old Apr 9, 2013 | 11:16 AM
Iowa999's Avatar
Pretty hilarious, eh? My guess is that the thread-starter is using the word "resonator" for "cat," because, as you so wonderfully pointed out, the Tomei Expreme doesn't have a resonator.
Old Apr 10, 2013 | 04:40 PM
anwkid's Avatar
I just made a quick test pipe on mine, sounded way better but it does have a slight drone at certain rpms...
Old Apr 11, 2013 | 07:26 AM
Iowa999's Avatar
Just to complete this thought: the entire purpose of a resonator is to combat drone. This is why they need to be placed a certain location and the optimum location depends on the piping, whether you have a cat, what kind of downpipe you have, etc. If, after you have created your exhaust, it drones, then you can add a resonator back in. You can try to do the incredibly complicated math to calculate where it needs to be located or you can just use trial-and-error, starting with the OE location and tweaking. In contrast to how I approach suspensions, I suggest the latter route. Why? Because I can't do the math for exhaust flow.
Old Apr 12, 2013 | 03:35 AM
elim0's Avatar
hahaha ohhh lol i was so confused i even google'd it incase there was a model with a resonator lol.
easy.. just get a 100cel hi flo cat//OR a test pipe and dump pipe and your car will be plenty loud .. i want a tomei expreme ti, but i cant justify the cost as i already have a full 3" TBE
