Sponsored by:
Sponsored by: CARiD
Need a bit of advice/knowledge
Old Apr 10, 2013 | 06:40 AM
Orodi's Avatar
I have an 08 GSR, full TB exhaust, IC and piping, EBC, intake, and stock motor and drivetrain minus stg1 clutch. Im kicking around the idea of go to e85. Not sure what all I would need to switch over. Im also not sure of the pro/con. I tried searching e85 on here and didnt come up with anything for the Evo X. I was planning upgrading injectors to 1,000cc but if I switch to e85....
Im looking at the power gains to be had by making the switch, but my concerns are losing a ton of MPG. right now with the cc and doing 65 I am hitting between 30-34mpg. With a range of 340-360miles per tank. Im ok with losing a little.
Thanks for the help
Old Apr 10, 2013 | 08:10 AM
Leezon's Avatar
Yup, those injectors will do fine and I'd also recommend a new fuel pump. Power gains you should see around 360-390 hp on a dynojet.
MPG will of course go down.
Old Apr 10, 2013 | 08:18 AM
ogrenator's Avatar
the gains above seem about right for what you have....how are you getting 34 mpg tho?? that's nuts...and where in cbus are you...idk if Ive seen you around
Old Apr 10, 2013 | 09:15 AM
teameditevo08's Avatar
Yea that gas mileage sounds great i want your set up lol
Old Apr 10, 2013 | 11:15 AM
Orodi's Avatar
im in Galena, drive up and down polaris almost every day, i know two with WW Xs. On black dude I see at Slowmotion alot and the other is a white guy rolling around.
Old Apr 10, 2013 | 11:17 AM
Orodi's Avatar
Right now I am at 326hp 330tq, im more or less trying to squeeze extra HP with out adding a pile of parts etc. this is my dd. and the fuel economy im ok with losing a bit as of course it will go down but I was more worried about a drastic change.
In short I have no idea what the pros and cons of e85 are. Just know you can build more power lol
Old Apr 10, 2013 | 12:09 PM
AWDTerror's Avatar
e85 uses more energy per gallon to burn. Expect about a 10-15mpg decrease switching to e85.
e85 lets you push the tune to be more aggressive and let you push an insane amount of torque with the stock turbo. There is a real fine line and you significantly up your chances of blowing the motor up depending on the tune and the final torque numbers.
Old Apr 10, 2013 | 12:10 PM
Iowa999's Avatar
The better way to say that is that e85 has less energy per gallon when burned.
Old Apr 10, 2013 | 01:29 PM
ikt's Avatar
ikt
You only need injectors, nothing else. If you go over 800cc, you might want a new pump. Stock pump flows 240 LPH, so get to at least 300 if you're gonna.
I've been on E85 for years, with a Cobb AP and tune by hollywood_x
Average 22 mpgish, 365 wtq and 360whp, dialed back from the max tho
not a single problem.
Old Apr 10, 2013 | 01:41 PM
ikt's Avatar
ikt
this.
fqjdmct9a
E85 / Ethanol
15
Feb 13, 2013 04:58 PM
Czarcasm
22
Jan 30, 2013 11:01 AM
EVOWRC111
18
Dec 2, 2012 01:31 PM
steven121
Oct 28, 2012 06:33 PM
evo8nyc
Jan 21, 2011 02:09 PM
