Sponsored by:
Sponsored by: CARiD
Not hitting peak boost of 26psi +/- 1.5
Old May 3, 2013 | 02:11 PM
cjs_evoxgsr's Avatar
I'm currently running Cobb stage 1 stock intake ACN91 octane Beta V400 map. Im hitting 22.5psi. Before I do a boost leak test, do you guys think removing the boost pill on a stage 1 map will help? Only mod I have is a K&N drop in filter. All other data seems to be fine. I get 1-2 knock counts but its not consistent throughout my logs.
Also, I will be flashing stage 2 once get a wideband. I have a ets test pipe and V2 catback exhaust waiting for install.
Old May 3, 2013 | 05:11 PM
EvilRob's Avatar
it says so right on cobbs site that if you are not hitting your target boost to remove the pill
Old May 3, 2013 | 08:47 PM
It says that for stage 2! im running stage 1.
Old May 4, 2013 | 11:50 AM
EvilRob's Avatar
I thought all the new beta maps are for stage 2 only plus don't the v400 maps require cobbs boost controller
Old May 4, 2013 | 12:17 PM
JonGonzo's Avatar
They have stage 2 maps with and without EBCS.
https://forums.cobbtuning.com/forums...volution-X-GSR
Old May 5, 2013 | 08:48 PM
sparky's Avatar
Wow. What is this thread about?
Old May 6, 2013 | 07:47 AM
hackerrei's Avatar
Switch to the LWG maps that should help but just for you to know most every one has knock on the stock maps bet to get a protune for the best results.
Side note when I took my app off the car unmarried it the app did not copy my stock map correct and my boost was all messed up with spikes and drop off got a pro tuned and fixed it check out my dyno sheet to see the difference.
https://www.evolutionm.net/forums/at...1-gsr-tune.jpg
Old May 6, 2013 | 08:49 AM
Veronica's Avatar
[deleted my response - it was irrelevant]
Old May 10, 2013 | 07:33 AM
UPDATE:
I installed my test pipe and V2 catback and flashed stage 2 ACN91 octane Beta V400. I kept the boost pill in and im hitting 26 psi now. Still waiting for my wideband to come in the mail but everything looks good so far!
ckevoxnyc
Cobb AccessPORT
May 30, 2017 08:54 AM
The_Police
Cobb AccessPORT
May 26, 2014 07:12 AM
EvoXRed
Jul 5, 2011 07:34 AM
GetterDragun
Oct 7, 2010 08:07 AM
SOG RA
Jul 28, 2010 08:24 PM
