Sponsored by:
Sponsored by: CARiD
Engine stalls
Old May 9, 2013 | 04:25 PM
terrorz75's Avatar
Engine stalls
I posted a thread awhile ago, but can't find it anymore.
The advice that was given was to change the Fuel Pump relay which I have done and I recently got the black relay the newer one from SSP performance.
and the engine still stalls whenever I turn the heater or A/C on. Can there be another reason why and how to fix it? I also checked the vacuum line and it didn't pop out.
There is also weird click when the heater or A/C engages. I'm thinking that the sound of the system turning on. But I could be wrong.
Old May 9, 2013 | 05:56 PM
Leezon's Avatar
What kind of intake do you have? It's common for this to open with a cone filter and no heat shield.
Old May 10, 2013 | 05:07 AM
evokid4life's Avatar
+1 you needs a heat shield!
Old May 10, 2013 | 06:42 AM
Iowa999's Avatar
Get a voltmeter and measure system voltage when you turn the heater and/or AC on. If the fans cause a large drop, there's your problem.
Old May 10, 2013 | 08:01 AM
terrorz75's Avatar
I'm using the Filter from Cobb and running the old stage 2 for GSR and on 93 octane. I don't have a heat sheild on.
Should I just use the stock box but use half of it instead of the cover on top?
@Iowa999, how do I use the volt meter? I'm not good with electrical stuff. Can you help please?
Old May 10, 2013 | 08:39 AM
atombomb33's Avatar
EvoM Community Team
Were you looking for one of these threads:
https://www.evolutionm.net/forums/ev...ne-stalls.html
https://www.evolutionm.net/forums/ev...ump-relay.html
Modz
Oct 31, 2015 07:35 AM
akdmks
Feb 6, 2015 10:27 PM
kingjhay723
12
Mar 23, 2014 07:13 PM
kd5byb
Lancer Troubleshooting
Sep 7, 2013 05:44 AM
Tbtalon94
AEM EMS
Jun 14, 2012 07:02 AM
