Sponsored by:
Sponsored by: CARiD
alignment
Old May 16, 2013 | 07:02 AM
chunkd's Avatar
alignment
Car pulls slightly right after alignment...
Tech flipped camber bolt and is saying this may be the issue.. wants to put car back to mits spec to fix the pull!!!
Here are my numbers after alignment
F/L caster 4.2, camber -1.6, toe 0.05
F/R caster 4.3, camber -1.9, toe 0.00
R/L camber -0.9, 0.00 toe
R/R camber -1.0, 0.00 toe
What would cause the slight pull right?
Steering wheel is slightly crooked to the right but he is going to fix that.
Old May 16, 2013 | 07:48 AM
bstgsr's Avatar
Sometimes the tires and have wear so that the car would pull slightly left or right, if its gone a long time out of alignment. How much is the steering wheel turned when u let the steering wheel go while driving?
Old May 16, 2013 | 07:56 AM
chunkd's Avatar
Tires are brand new... the wheel is about 3 degrees crooked right but he said he'll fix that.
The slight pull to the right the wheel moves about 2 degrees.
Old May 16, 2013 | 11:37 AM
Iowa999's Avatar
More left-front toe-in than right-front, and, yet, you have to steer right (some more) to go straight. Sounds like the steering wheel wasn't close to straight when the alignment was done.
goofygrin
88
Jul 24, 2022 08:22 PM
LV///R
81
Mar 23, 2015 07:40 PM
gunhaha
Jul 24, 2014 12:43 PM
eVoRox
May 27, 2014 07:45 AM
hispanicpanic
10
Mar 1, 2014 04:07 PM
