Sponsored by:
Sponsored by: CARiD
Spark Plug Failure. HELP!
Old Jul 6, 2013 | 11:33 AM
Jake.barratt's Avatar
I had a failed spark plug at 4k
Old Jul 6, 2013 | 02:12 PM
Jubey97's Avatar
Do you know what caused it? What did you ended up doing? If you did an engine build can you pm me how much was the cost total? Thanks.
Old Jul 11, 2013 | 06:53 AM
acidtonic's Avatar
I made it 12K without any problems so far.... Do you guys really change plugs every 10K though? Car seems to be running fine and after hearing about failures it makes me not want to mess with it.
Changed plugs multiple times on my IX without any problems. You guys are making me nervous on the X.
Old Jul 11, 2013 | 07:07 AM
Kracka's Avatar
I change mine about once per year, or more often if the car sits on the rev-limiter for an extended period since that is what's causing the failures in my experience.
Old Jul 11, 2013 | 08:35 AM
teameditevo08's Avatar
For those regularly changing your plugs are you getting them from mitsubishi or straight from ngk?
Old Jul 11, 2013 | 10:30 AM
Kracka's Avatar
I vary between my local dealer (Don Herring Mitsu) and MAP depending on which is more convenient at the time since they're about the same price either way (~$50-55). The plugs are identical when compared side-by-side.
Eartears
23
Mar 1, 2017 11:53 AM
Ferp
Jan 23, 2017 09:42 PM
Casey Robertson
Mar 18, 2016 03:35 PM
Sheasta
Jan 30, 2016 10:48 PM
xgamer
Feb 17, 2013 04:58 PM
