Sponsored by:
Sponsored by: CARiD
stock appearing turbos?
Old Jul 15, 2013 | 06:06 PM
surferjeff's Avatar
What are my options other than FP and BBK.Any suggestions are welcome thanks
Old Jul 15, 2013 | 07:16 PM
rkelley's Avatar
MAPerformance turbos are good turbos and customer service is good. The ef series are stock frame made from original MHI housings. What are your power goals?
Old Jul 15, 2013 | 08:22 PM
surferjeff's Avatar
I'm wanting 400 to 425 stock cams pump gas I run e85 on my evo 8my evo x is my daily but I wanted to spice it up.
Old Jul 15, 2013 | 08:24 PM
surferjeff's Avatar
Do the map turbos bolt up to the stock manifold?
Old Jul 16, 2013 | 03:40 AM
rkelley's Avatar
Yes. The ef series are stock frame turbos. They also offer the option of upgrading your current turbo if you want to send it in.
Old Jul 16, 2013 | 10:28 AM
bphx123's Avatar
yeah id deff go with map ef3
Old Jul 16, 2013 | 10:50 AM
Kendogg's Avatar
When you upgrade your turbo, what else would you need to upgrade so that you get the full potential?
Old Jul 16, 2013 | 10:58 AM
Kracka's Avatar
No reason to go that big for his 400-425 goals.
I say pick what your goal is...400 or 425? I've had both the EF2 and EF2.5; if you want closer to 400 get the EF2, if you'd rather be closer to 425 and willing to give up a bit of response and spool get the EF2.5.
I'm currently at 425whp/400wtq with the EF2.5 on stock cams and pump gas.
Old Jul 16, 2013 | 11:56 AM
r34p3rex's Avatar
A stockframe GTX3071R would meet your power goals
Old Jul 16, 2013 | 01:46 PM
Kendogg's Avatar
Ok, this is probably a dumb/nnob question. It's not possible to twin turbo it? Keep the stock for the quicker spool and get a larger one for the additional power?
Old Jul 16, 2013 | 03:29 PM
Iowa999's Avatar
If nothing else, where would you put the second turbo? There's rather little room between the engine and the firewall.
Old Jul 16, 2013 | 03:33 PM
surferjeff's Avatar
Basically I want the same mods I currently have DP TP stock ehaust stock piping and inter cooler intake with drop in filter and I want 420 whp pump gas which turbo you guys think will acheive this goal I want a sleeper.
It would cost way more than its worth to try and set something like this up sir just do what I'm doing you will love the finish product.
Old Jul 16, 2013 | 03:37 PM
surferjeff's Avatar
My car sounds bone stock and I love that took some people for a ride and was doing second third gear pulls and they were like damn this thing is fast.wait to I put something equivalent to red in there lol.p.s I told them it was bone stock lol
Old Jul 16, 2013 | 03:53 PM
Kracka's Avatar
EF3 would be equivalent to the Red.
Old Jul 16, 2013 | 04:20 PM
surferjeff's Avatar
Would the ef 2.5 be enough to meet my goals with almost everything stock?oh I have a 3port boost controller.I forgot to put that in my last post.I used to have a red in my evo 8 I loved that turbo.unfortunately the bearing died and the turbo touched down:(.
