Sponsored by:
Sponsored by: CARiD
Please help me (boost controller issue)
Old Aug 18, 2013 | 02:20 AM
yamo0o3's Avatar
Angry Please help me (boost controller issue)
Hi all
I have HKS EVC 6 Boost Controller so I wont to decrease the boost do any one know how ??
Be Couse it in moods (A1.5) (B2.0) (C!!3)
So I wont to make it (A0.5) (B1.0) (C1.5)
If any one knows how please help me
Thank you very much
Old Aug 18, 2013 | 04:18 AM
yamo0o3's Avatar
Please help me
this Pic
Old Aug 19, 2013 | 12:06 AM
yamo0o3's Avatar
Any now no how ???
Old Aug 19, 2013 | 08:50 AM
jstalford's Avatar
Try sending a PM to this guy:
https://www.evolutionm.net/forums/me...turbodawg.html
Old Aug 19, 2013 | 09:44 AM
ikt's Avatar
ikt
sell it and get a 3 port and a tune, you don't want that thing
Old Aug 19, 2013 | 09:54 AM
ikt's Avatar
ikt
until then, here is how to set your boost
3.Setting the Standard Maximum Boost Setting
Turn the volume knob and set the max baseline /default boost value if the boost value is known.I. The value will then be shownin the digital display
-speed/RPM display set to "N"
・・Enter the max boost value that is stable
Or here is for the standard mode I guess
1)In the Stanards Mode, press the volume knob to set・The EVC will beep and P.H.will illuminate; thedigital display (S) changes from peak hold displayto the blinking target boost value.・"SET" will also illuminate.・To set value for B Mode, select B Mode with thevolume knob (turn right), then press knob.(2)Turn the volume knob to set the target boost value.When the value is selected, press the volume knob again.・The EVC will beep and the displays returns to peakhold display.・The selection range is from baseline boost to250kPa / 36.0 PSI.・The target boost value set in the initial setting isthe default value for booth A & B Modes.(1)Press the volume knob for more than 1 second・The peak hold value will cleared and reset to0 kPa or 0.0 PSI accordingly.Set the boost values for A/B modes in the Standard Mode.Activate the Scramble boost function by pressing Button① or the external scramble switch.
3.3.Scramble
(1)After pressing Button① or the external scrambleto trigger its activation, the EVC will.・Beep to indicate that the function is active.・The bar graph and "SBC" will blick and the remainingtime of the scramble will be displayed on the digitaldisplay (S).・When using the user preset time function of theScramble, the countdown does not begin until therelease of the button or external switch.(3)To turn the EVC off, press Button② for more than 1second. Repeat set to turn the EVC on.・An audible beep will be emitted to confirm action.・When the EVC is off, the current boost reading and thePeak Hold value will be the only data displayed.
here is the manual for it:
http://www.scribd.com/doc/22538022/HKS-EVC-6-Manual
Old Aug 19, 2013 | 09:05 PM
yamo0o3's Avatar
Thumbs up
Thanx all for help me
Old Aug 20, 2013 | 02:45 PM
ikt's Avatar
ikt
welcome to evoM
Moore Auto
Vendor Classifieds
49
Sep 24, 2017 11:30 PM
bluepeartype-s
Dec 13, 2015 12:20 PM
LOWPROaero
41
May 20, 2013 12:01 PM
Moore Auto
Moore Automotive
Oct 9, 2012 01:19 PM
psphinx81
For Sale - Cars For Sale
Nov 29, 2007 10:35 AM
