Boost gauge vacuum line...?
I am getting ready to install a boost gauge this weekend and I have seen several threads recommending the BOV vac line as the best place to tap in for a boost gauge. This seems to go against conventional thinking to me. I was wondering if there is a consensus best vacuum source for a boost gauge that I just havent been able to find. Thoughts?
I have searched everywhere and I cant find anything about where to tap the vacuum line...no one has any info on this? I know there are a lot of boost gauges on X's out there...lol
I followed this how to and my boost gauge works perfect. Took some time but there are no wires showing and very clean! I have an AEM boost gauge
https://www.evolutionm.net/forums/ev...lean-hell.html
I have never heard that, interesting. Makes sense.
I'm not talking about the actual FPR line though, but a FP Solenoid. All it does is allow the ECU to temporarily raise fuel pressure for the purpose of hot starts. I have always heard of it as being a good place to tap. However, it very well may be that evos have a different and better method to accomplish hot starts than a solenoid, and maybe it is not even present?
Ah, yes. In fact, the line on my DSM came off the cold-start solenoid hose, IIRC. It was convenient, being right there on the firewall, near the rubber boot for the steering column, which is where I ran it into the cabin. NVM.
No idea if we have a physical (instead of software) cold-start valve on our cars. Wouldn't surprise me if it all was software.
I tapped into the vac line to the BOV...works like a champ!
I've always ran PSI Gauges off the T next to the turbo but when I did it on my X it only read boost and not vac...
Its the easiest line to tap and after several thousand miles, I've ran into no issues ;-)
Good info, thanks.
EvoIXPilot
Nov 30, 2012 06:46 PM
