Sponsored by:
Sponsored by: CARiD
AEM Boost gauge "---" help!?!?!
Old Sep 6, 2013 | 09:20 AM
Thebeatinben's Avatar
Question AEM Boost gauge "---" help!?!?!
Hey EvoM,
So awhile back i picked up an AEM Digital boost gauge and it shows "---". It did work once during the install but after I finished the install it showed "---" ever since. I've gone back and redone all the wiring and still does it.
Should I just pick up a new AEM Digital and swap out the sensor and then return it? Reason why i'd just replace the sensor is because i had to cut and extend the wires to reach my pods.
Or should i grab something new. Maybe Innovate MTX-D or any suggestions?
Old Sep 6, 2013 | 09:22 AM
zanelefko's Avatar
I would call AEM, being that you cut the wires you may be out of luck.
Old Sep 6, 2013 | 09:23 AM
Iowa999's Avatar
Two possibilities come immediately to mind:
you crossed or shorted the wires while adding your extension
you used wire that was too thin, such that the total resistance is now too high
Old Sep 6, 2013 | 12:18 PM
Well i did contact MAPerformance which was where i purchased my gauge. They redirected me to AEM and said that they'll contact me and never did.. This was back in June. But anyways like i kinda said should i stick with the AEM or move on to another brand?
I'm sure i didn't cross the wires even if i did i went back and redid it the second time. Everything is color coordinated. You may be right about the wire being shorted and also about the wire being to thin. Is there a way to tell if it's too thin?
EDIT: Oh i forgot to mention i have a AEM wide band hooked up and it works perfectly....
Simon Zhou
Sep 12, 2016 11:44 PM
LtownEvo
Feb 18, 2016 03:35 PM
maperformance
Evo 'For Sale' Electronics / Lighting / Audio
591
Mar 6, 2015 07:21 AM
evodrivesme
Aug 10, 2014 08:39 PM
Ian0611
13
Apr 3, 2013 01:21 PM
