Sponsored by:
Sponsored by: CARiD
schrothe rallye 4 install
Old Jan 1, 2016 | 09:42 AM
Roger350's Avatar
You can do driver and passenger Rallye 3 harnesses properly mounted to the "package shelf" OEM shoulder belt locations. I have 2 sets in my car for HPDE weekends. There are 3 mount points in this area, and each Rallye 3 harness only requires a single tail mount point.
You can also do 2 Rallye 4 belts mounted to the lower OEM lap belt points and deal with the extreme vertical angles.
But if you're doing a cage don't waste the money on the Rallye 3 or 4, get proper 5 or 6 point belts that are 3" wide webbing and attach them to the cross bar of your cage.
The Rallye 3 & 4 are "Tuner" belts. Most people have them for looks. I think some retailers throw in a free fart can exhaust tip with a set of two.
The rest of us use the Rallye 3 & 4 for HPDE or autocross as a compromise that holds us in place much better than the OEM belts but with some inherent risk. They work well for me, and I am not at a point that I would consider a cage, seat, HANS, etc.
If you're caging the car skip the tuner belts and get a real harness setup.
Old Jan 3, 2016 | 07:18 PM
Strangways's Avatar
If you just want to be held in the seat better, get a CG-Lock. Surprisingly effective, and totally safe.
killerpenguin21
Motor Sports Parts
Aug 10, 2017 04:53 PM
killerpenguin21
Aug 10, 2017 04:39 PM
LV///R
Apr 13, 2017 10:06 AM
badev0
Jan 24, 2017 08:20 PM
EatSleepBoost
Mar 18, 2016 06:55 AM
