Oil cooler is bent
Oil cooler is bent
What's going on Evom. I'm rarely on here. But I think I'm gonna start. Anyway it appears that my oil cooler is slightly bent. Not sure from where, but when I turn the wheel left it slightly hits it. Also you can kinda see it's sitting crooked in there.
What normally would normally be causing it to be bent. It was slightly hit. But just trying to get an idea what would need to be repaired. Brackets which I am thinking. Any ideas would be great. Should I try to bend it back so it will not run against my tire when turning sharply..
I run 26" tires on a +18 offset and don't come close to the oil cooler. I doubt that that's the issue. Bent or loose bracket sounds correct. Lucky that the oil cooler has flexible lines, eh?
overlord2kx
Nov 30, 2010 08:55 AM
