Engine shaking
Engine shaking
Hello..
I have a major problem I know what I need to do but I cant get it done till saturday on the mean while I wanna see if anybody can tell me if I can fix this temporary my car has been running lean so it caused to check engine light came on.. is there anyway to fix this? Increase the fuel pressure some how?
First off take a look at your plugs, check gaps and then test each plug for a spark. If that is all good then reinstall or replace if bad. Do another test
Then next thing is to start checking your fuel system, inspect your injectors. Maybe cyl# injector needs cleaning. Id do then all anyway. Once you have checked that then retest
Now if still exists then check all vacuums, make sure you have no damaged lines, clamps are good etc and retest again.
I recommend doing it in this order and testing every stage as it will give you a process of elimination, instead of checking everything at the same time and then not really knowing what the problem really was. If all these are working correctly then it's probably time to dig deeper, maybe you have a bad ring on cyl#4
Check spark plugs, check fuel pump relay, and if those aren't it then stop driving it and have it towed. From what I know, sounds to me like you're driving your car with the improper tune.
Dragon123
Oct 1, 2016 03:04 PM
