Sponsored by:
Sponsored by: CARiD
Doesn't go into gear smooth
Old Nov 29, 2013 | 09:09 PM
kevinlambchops's Avatar
Got a 2012 gsr with 6k miles on it. First manual car that is mine. Driven friends si in the past and such. Well when I shift into the gears it doesn't seem to go in smoothly. I drove my friends civic si 9th gen and it seems to go in much more smoothly than on my car. Is something wrong, or is this something that is common with evos?
Old Nov 29, 2013 | 10:18 PM
Or is this due to driver error?
Old Nov 30, 2013 | 12:24 AM
DVanDuzer's Avatar
My 2014 has been notchy since I bought it - only has 2000 miles on it.
Old Nov 30, 2013 | 02:18 AM
BehindSpace999's Avatar
it's normal, the transmission is VERY notchy until the transmission fluid gets hot and i mean one hour worth of shifting hot, then it becomes surprisngly smooth.
otherwise, expect to be notchy and maybe even grind if you try to shift fast.
to give you an example, brand new 2013 here, and when the fluid's cold i cant shift normally from 1st to 2nd or 2nd to 3rd, i have to shift slowly and pause at neutral or double clutch to make it go in smooth.
Old Nov 30, 2013 | 08:53 AM
Iowa999's Avatar
We didn't need a new thread on this. There's even a sticky about it: https://www.evolutionm.net/forums/ev...on-thread.html
Dross99_si
Evo X Dyno Results
37
Jan 17, 2018 01:06 PM
roguesturgeon
Mar 17, 2016 09:36 AM
fengzhaoxi
Mar 2, 2010 02:48 PM
fxyxixe
14
Feb 8, 2007 06:42 PM
si_eater
Jul 13, 2005 09:09 AM
